engine removal and rebuild
But it didn’t. So I think there’s a crack on both of them. So I got new ones.
Belmon (01-16-2018)
#30
Only one valve matched up to the right side with low compression the left side I’m going to look at more closely tomorrow after work. It’s a good thing I took the engine out and apart some of the rod bearings were starting to spin now. I need to translate the bearing codes to get the colors and de grease the engine and find a place to hot tank the block/main bearing plate/sump/heads. And get a straight edge to check if the head/block it true.
#32
And on the head bolts bob I found that my 13mm was fitting loosely and felt like it wanted to round out the bolt heads so I went to a 1/2” Crome deep socket and it fit a little tighter. That worked for the left head. But it broke on the right one then I got a 12 point 1/2” impact socket for the rest. Also bob what tool do you use to get the valves out. I went to some auto parts store and the ones they rent won’t work for these heads because the valve springs are in there own little pockets.
#33
The one I have is similar to the one in the link. I won't vouch for the quality of this one but the one I have was around $90.
https://www.googleadservices.com/pag...3D%26veh%3Dsem
I use a multi compartment container and put everything from each valve in its own compartment and mark where it came from. I like to put everything back together the exact way it came out.
Be careful of the retainers. They are very small and can be easily lost. Have a clean area for disassembly and assembly. You will probably drop a few and they will be hard to find if it's a cluttered area.
Edit: If you are having a machine shop do your heads let them do the disassembly. On my heads I did it myself since mine only needed to be lapped in but if the seats or valves are bad enough that they need machine work I would let a machine shop do the work.
Belmon (01-16-2018)
#34
#35
I don't think that will work. Even with a spring compressor it is difficult to reinstall the retainers. You will have more access to get them in with the spring compressor.
I cleaned my heads with the purple degreaser and a pressure washer. The almost looked new when I was done.
First pic is my Harbor freight container then the before and after on cleaning the heads.
Belmon (01-16-2018)
#36
The problem is washing it. They tore down some self car washing places and are rebuilding them. I might just buy a big tub to dip the heads in degreaser. Not sure about the block yet. I’ll look around for a place.
Belmon (01-16-2018)
#39
ok so i think i got the right bearing colors but i would like someone else to double check my work to be sure
engine numbers sjgkf*baab 22222223*rrnrp
link to engine pdf http://www.jagrepair.com/images/Auto...Code%20168.pdf
pages 54-59
rod bearing color
b/1 green
a/2 blue
a/3 blue
b/4 green
main bearings crank journal diameter
s/1 61.985mm
j/2 61.992mm
g/3 61.994mm
k/4 61.991mm
f/5 61.995mm
main bearing bore inside diameter
r/1 66.018mm
r/2 66.018mm
n/3 66.020mm
r/4 66.018mm
p/5 66.019mm
main bearing color
1 blue/green
2 blue/blue
3 blue/blue
4 blue/blue
5 blue/blue
cylinder bore
2 b1
2 b2
2 b3
2 b4
2 a4
2 a3
2 a2
3 a1
pages 54-59
rod bearing color
b/1 green
a/2 blue
a/3 blue
b/4 green
s/1 61.985mm
j/2 61.992mm
g/3 61.994mm
k/4 61.991mm
f/5 61.995mm
r/1 66.018mm
r/2 66.018mm
n/3 66.020mm
r/4 66.018mm
p/5 66.019mm
main bearing color
1 blue/green
2 blue/blue
3 blue/blue
4 blue/blue
5 blue/blue
cylinder bore
2 b1
2 b2
2 b3
2 b4
2 a4
2 a3
2 a2
3 a1
