FINALLY - aftermarket radio and custom fascia in my XJ8 !!!
As George has stated on several occasions that this will be a one off piece, I thought I'd try and help you guys out by posting a link to a similar thread
https://www.jaguarforums.com/forum/x...it-ebay-50635/
It has good write ups and is a good price.
S.
S.
reikioz (12-22-2011)
I do think the piece that George had made looks much more "factory" than the ebay adapter. I had previously seen the ebay item but felt it looked kind of "Pep Boys", especially with the leaper which seemed a bit tacky. One of the key design diffs with George's unit is that his 1-DIN radio is centered in the mount rather than sitting near the bottom.
I did notice, after my first posting, that George said this was a one off piece. At the same time, the hope is that if if George conveyed the high level of interest to the fabricator that the guy might consider making up some more. Generally, the first is the most costly and time consuming.
We may ultimately need China to provide something more modern looking. You might want to visit these guys and submit a request for a unit that will fit the XJ. If enough people ask, they may produce something (they have a "contact us" link near bottom of page).
Car Dvd Players, Gps Navigation, Gps Navigation Systems, In Dash Dvd Player
S.
S.
The leaper is optional on the ebay units, you can have it with or without. You won't get another adaptor like George's unless you go about having one made yourself and having a batch produced for sale.
I'm not going to go with a after market stereo now because I have a FM transmitter that is discreet and works well. I have a tape adaptor that works well and causes me no issues, and I can use either as a hands free kit with my phone which is also my MP3 player.
I would be tempted by a double Din touch screen set up if you could fit it into the XJ8, but with the module located behind the stereo this causes issues sadly.
Have alook at this post, might be helpful.
Cheers,
Frank
http://j.roal.home.mchsi.com/X308Bluetooth.pdf
or this one
https://www.jaguarforums.com/forum/x...ontrols-56937/
Cheers,
Frank
or this one
#30
Park and Reverse Sensors
Anyone know the best location to tie into the park brake switch and reverse sensor?
I have a system that needs to tie in to these two points for correct operation (don't want to bypass). DVD requires park brake on, and rear view camera option activates when reverse selected.
I Have JTIS and the wiring schematics, but unable to find a suitable point and not sure how the DVD system detection works (i.e. current sensing)? Don't want to connect to a point that may mess with the control module operation.
Any ideas, comments, suggestions most welcome.
Thanks.
Thanks.
#31
beaky,
Do an ebay search for "park brake bypass" and you will find multiple switches for many different head units. With this you do not need to wire into the park brake and you can "watch" DVDs while you are driving--which I do not recommend but it is do able. They are all around $10-$20 very worth it.
For the back up lights, I did this on another vehicle, but I just connected it to the actual backup light in the trunk. It was right near where I was mounting the camera.
Hope this helps
Joe
Hope this helps
Joe
#32
#33
I Found it !
Have a look here ..
Hard To Find Radio Dash Kits
Finally! A faceplate adapter kit that allows you to take out that old factory cassette and put in a modern radio of your choice with features like iPod connection,
Satellite Radio and Bluetooth hands-free!
Cheers,
Frank
Have a look here ..
Cheers,
Frank
#34
For my tastes, the 1-din sits too low. Would look better if it were centered in the adapter more like the custom fabricated unit discussed earlier.
Btw, on many navi systems you just hook the parking brake wire to ground and that gives you the bypass.
#35
That is the eBay adapter.
That's all very well, except for the fact that the custom made unit isn't available! Beggars etc..
Cheers,
Frank
#36
Cheers,
Frank
or this one
Cheers,
Frank
or this one
Unfortunately, it does not look like the XK8 solution will work in our XJ series. Just enough diff in layout of switches to make it a no go. If it did work, it would provide a much cleaner looking integration.
Perhaps the ebay unit could be modified to install the HU at a slight angle but raise it so it is not sitting almost flush at the bottom? The ebay facia is so close but just far enough off to look K-mart.
#37
I just installed a Kenwood radio in my 2000 XJ8 VDP, using the aftermarket fascia from Greg (sealevel@san.rr.com) along with a steering wheel control adapter, and subwoofer amplifier from Cruchfield. Of course the Nav is no longer installed, but everything else on the car functions as usual. The sound improvement with the new electronics and Pioneer door speakers is dramatic.
#38
Any Photos of the installed Kenwood?
I really would like to go with something newer but so many of the aftermarket units look so out of place in the XJ8. I am surprised that the Chinese manufacturers have not come up with something that looks factory as they have done for so many other models.
#39
Originally Posted by [B
linuxenigma[/B];483865]I just installed a Kenwood radio in my 2000 XJ8 VDP, using the aftermarket fascia from Greg (sealevel@san.rr.com) along with a steering wheel control adapter, and subwoofer amplifier from Cruchfield. Of course the Nav is no longer installed, but everything else on the car functions as usual. The sound improvement with the new electronics and Pioneer door speakers is dramatic. .
Thanks.
