Fuel Sound from Rear.
Old Apr 15, 2017 | 08:40 PM
omgimali's Avatar
Default Fuel Sound from Rear.
6/10 when I start my car at temp (not cold) there is a noise from the rear like fuel shaking or circulating vigorously and the idle is real bad, and if I give it gas it will stall or cure it self, if I don't then it will go away in 20-30 seconds.
Old Apr 16, 2017 | 05:00 AM
Sean B's Avatar
put some gas in it! Seriously, fuel pumps on these cars are notorious for failure and it sounds like your pump is on its way out - don't let it try and scavenge fuel - lots of info about this on the forum.
Old Apr 16, 2017 | 12:08 PM
omgimali's Avatar
I do have gas in it. The last time it happen was when I left the gas station with half tank of fuel. Fuel Pump is going out then? I have read about it on the forums.
Old Apr 16, 2017 | 12:15 PM
omgimali's Avatar
What Fuel Pump is good? I've seen a lot of cheap ones, any good specific brand?
Old Apr 16, 2017 | 12:17 PM
Sean B's Avatar
So you have an initial bad idle/stall, with fuel noises - a possible in-tank fuel line fracture. Or a few other things.
Try and check fuel pressure at the injection rail, I think it's front drivers side, when you energize the ignition system the pump should prime up around 40psi at this valve, the pressure can tell you whats going on engine side.
Old Apr 16, 2017 | 12:30 PM
omgimali's Avatar
Where do I get the fuel pressure test?
Old Apr 16, 2017 | 03:07 PM
RJ237's Avatar
See if Autozone has a kit to loan. I bought one at Harbor Freight that works okay.
Old Apr 17, 2017 | 11:31 AM
Addicted2boost's Avatar
The fuel pressure test port is located under the " beautification panel" on bank one.
Get a Denso fuel pump from amazon and a new sock to go with it. You can never go wrong with Denso parts.
Old Apr 17, 2017 | 01:31 PM
Ahenry014's Avatar
x2 on denso parts. I bought this pump from amazon:
http://a.co/5vfn9Wo
just a small modification to the upper rubber grommet around the inlet and plug, splice the new plug on, and you are in business. Im told the only direct replacement pump, just plug it in and go, is made by URO. Guess which brand pump had only 10k miles on it that i tossed in the trash?? Go denso.
Old Apr 17, 2017 | 03:37 PM
omgimali's Avatar
Alright thanks guys. The fuel pressure test from AutoZone is $130 for a loan deposit. What do I do to test it? Foot to floor and pressure test?
Old Apr 17, 2017 | 09:14 PM
Just pull the right hand side beautification panel off, pull the schrader valve out, turn the ignition key on but don't engage the starter. If you see a fountain of gas, pressure is not your problem. If it barely dribbles out, it's most likely a bad pump. I would replace the fuel filter after a pump change while your there anyways.
Old Apr 18, 2017 | 03:45 PM
omgimali's Avatar
Ok I can do that without a pressure test^?
Old Apr 18, 2017 | 04:56 PM
Sean B's Avatar
Yes - but please carry it out on a cold engine and have rags around the valve. This quick check is generally used on a crank and no start, but if your car is a non-starter no harm in checking.
Old Apr 18, 2017 | 05:06 PM
omgimali's Avatar
But how about my car runs perfectly which it does except the random stalls and bad idle.
Old Apr 18, 2017 | 05:23 PM
Sean B's Avatar
it all points to an intermittent pump which can be difficult to diagnose, it's time consuming running the car with a pressure tester until it fails as you have to watch the gauge. There shouldn't be audible gas noises so something needs looking at in the tank. Have you any engine warning lights/messages when it stalls?
Almost every owner has this fuel pump failure in their files or future. Have a look at this.
http://www.mediafire.com/file/377tqn...s+Rev.+1.3.pdf
Old Apr 18, 2017 | 05:28 PM
omgimali's Avatar
Whenever it stalls it says ENGINE STALLED nothing else and no codes. Should I replace the pump and filter as I have not and not wait in the future if I am stranded somewhere?
Old Apr 18, 2017 | 08:56 PM
If the pump has never been replaced, by all means replace it. When I bought my wife's 00' XJ8 at the end of 2013 with a whopping 21K miles on it, I purposely had it towed across town to where I work at and replaced the fuel pump, filter and metal impeller water pump because they are problematic. It's not just mileage that effects them, it's also the age.
AudioBob's Avatar
The hard thing about diagnosing a fuel pump is that it may run normal and pressure test normal before and during start up and while idling and driving until a complete failure. Usually fails once it gets hot and then completely shuts down. My last pump failure happened at 70 mph on the expressway and it was quick. Pulled over, started running again and failed again after a short period. I decided to get the car towed before I had a wreck.
Had the car towed home and bought a test gauge. The next day I tested it and the pressure was fine at start up and idle and everything else checked out fine so I narrowed it down to the pump. Replaced the pump, sock and filter and that solved the issue. As mentioned before, sometimes pumps are hard to diagnose unless they are completely dead. Unless you are going to DIY, take it to a shop and save yourself some aggravation and possibly an accident.
Old Apr 18, 2017 | 09:18 PM
omgimali's Avatar
Ok Thanks, My uncle once put water in the fuel tank by mistake. The shop charged $700 but I don't know what happened. I will change the pump and filter.
Old Apr 21, 2017 | 05:30 AM
Vector's Avatar
The pump can fail AND fry the wiring that goes to is as well.
When I had my (2) fuel pumps replaced in my XJR, the wiring pigtail(s) had to be replaced too. I guess the failing pump draws a lot of current and takes the wiring out with it when it goes.
So, be sure to inspect the wiring to the pump(s) "while you are in there."
Vector
