Is this heater circulation pump wornout?
Old Dec 30, 2014 | 09:33 PM
ReluctantMechanic's Avatar
Default Is this heater circulation pump wornout?
backside of impeller in my hand and separation plate with worn surface.
Should I replace this pump? What would I do to rebuild it? If I buy a used one how would I know if it d/n have the same wear? I know the motor is good, but not if this imperller is hanging up. Seems to turn even when dry??
Old Jan 14, 2015 | 01:43 PM
Dan R's Avatar
Replace the brushes and you should be OK. Check the boards for details.
Be careful to reassemble the motor carefully, it can bind. I used a dab of synthetic grease on the forward plain bearing.
jazzman20014
Oct 26, 2015 04:15 PM
dickc
Sep 21, 2015 02:04 PM
chatmanx
Sep 11, 2015 07:17 PM
Super Cat
Sep 11, 2015 08:14 AM
texaspete
Sep 10, 2015 08:34 AM
