2003 X308 coolant pressurizing
Gents, I am trying to pressurize my 2003 XJ8 cooling system chasing a mysterious slow leak. I have tried everything I can think of and bought every kind of new adaptor and pressurizer I know of to pressurize this cooling system. Nothing has worked so far. It seems this system has a two part sealing cap unlike all other systems I have encountered. When I queried elsewhere, I was advised to get a Mityvac MV4560 system as it did it all. News Flash, AFAIK, it does not do my X308 there being no two way sealing adaptor in the kit.
I even tried cobbling one up with an old pressure cap I had. No Joy.
SOOOOOooooooo, if any kind soul out there knows EXACTLY how to do a pressure test on the cooling system of the X308, please tell me in excruciating detail how it is done, preferably with pictures. Please also provide exact names and product numbers of any items used.
I have spent three frustrating days trying to pressurize the system chasing a mystery leak that leads to overheating. This is becoming ludicrous in the extreme.
Best regards to all, Brian
The following 2 users liked this post by RJ237:
Don B (04-14-2018),
MountainMan (04-23-2018)
Hmmm.
2003 = aged plastic parts.
I had EXACTLY the same problem.
Found out it was a brittle thermostat cap. It would "****" out a VERY light stream. Almost invisible to the naked eye, but I happened to notice it when I was searching for it. It was a sunny day and at just the right angle you could see it. When I found this "leak", it was doubtful it would even show up with a pressure tester because it was on the opposite side of the thermostat. If the stat is not open, no pressure will be evident.
This is only an example, but there are quite a few plastic parts associated with the cooling system in these cars.
I would start checking all the plastic in the system.
Especially those stupid, brittle bypass "hoses/tubes" that ALWAYS seem to break at the connectors.
I don't think you need a pressure tested, just bring the car up to temp and let the system pressurize itself. Then check all those stupid plastic tubes and parts that they use with corrosive coolant!
When you use a pressure tester the whole system is pressurized. The advantage of using it is you can pump to 15psi cold and leave it there. Some leaks are so small that the coolant evaporates and the leak is not detected, especially at the back, with a hot engine.
If the system holds pressure for several hours there are no leaks. It took me that long to find a leak at the Norma fitting above the exhaust system at the right rear.
Don B (04-14-2018),
The following 2 users liked this post by yeldogt:
Don B (04-14-2018),
Received 12,737 Likes
Hi susu,
I'm not positive this is true on the X308, but on many vehicles I've pressure-tested it is difficult or impossible to build pressure if the coolant level in the reservoir/expansion tank is low, so it would be worth checking yours.
I'll check my pressure-testing kit and confirm which adapter fits the X308 and post it in a little while.
Cheers,
Don
Cheers,
Don
WaterDragon
07-31-2016 02:38 PM
L80ous
02-20-2013 03:37 AM
