How to tell coolant level
Old Sep 15, 2014 | 04:12 PM
smith356's Avatar
Default How to tell coolant level
I have the low coolant level display on the dash. The coolant is to the top on the aux tank near the firewall. I tried pushing a pencil, eraser end, around in the tank, as per a post on here, but don't know if I did anything. Can I assume the radiator is full, and is there another way to check level ?
Thanks, Jim
Old Sep 15, 2014 | 05:29 PM
plums's Avatar
If you were trying to ensure the level sensor float is moving freely, you should be able to get your pencil onto the float and feel it move up and down as you move the pencil. The float is like a donut around a shaft.
During running, the coolant could be dropping because of air pockets, so you will want to be sure that the system is properly bled.
On a XJR, the bleed is the fitting on top of the supercharger intercooler.
Old Sep 15, 2014 | 07:09 PM
smith356's Avatar
Thanks, Plums.... I'll play around with it some more. I appreciate your response !
Jim
MrWhite
19
Jun 14, 2022 07:49 PM
X308XJR
May 20, 2019 06:50 PM
vwbusbits
Oct 13, 2015 03:43 AM
dmatthewman
Sep 30, 2015 10:10 AM
