IDS V118.5 anyone?
Hi - I'm looking to get hold of a copy of IDS V118.5
Anybody got a link, or willing to put an iso onto a share drive? Trying to find diagnostic software to work on a 2000MY XJR seems nigh on impossible. Cheers, Tom |
You will need a VCM (a common J2534 device will NOT work with IDS, only SDD version 125 onward)
Do you have an older Win XP 32 bit laptop? bob |
Hi Bob,
Thanks for the reply. Yes I've got old laptops coming out of my ears, so no problem there. I've just lost out on an auction for a full WDS system, which is a bit frustrating, so now I'm looking to make up a VCM solution. I'm a bit confused as the market seems to be flooded with VCM"2" units. Are these compatible, or do I need to keep looking for an original VCM? Then I'll use the old software 118.5, or maybe 125.03. All I want to do is clear/investigate this pesky lambda sensor fault (P1647) which remains even though I've changed the sensor twice and swapped left for right. I suspect a faulty engine ECU, but the replacement I have has the wrong CATS code so I can't just swap it over. |
When you swap an ECM to the car you will need to perform an IMMOBILIZATION SETUP.
There can be only one ECM configured to the car at a time. If you install the original ECM back into the car after installing another, you need to configure it back the car AGAIN. I don't think the VCM2 will be compatible. bob |
Originally Posted by Tombloke
(Post 1698392)
