Inoperative Drivers Seat 2000 XJ8
Old Feb 20, 2014 | 08:50 PM
h-barnes's Avatar
Default Inoperative Drivers Seat 2000 XJ8
My drivers seat quit working after I replaced the battery . All fuses check good . Memory switch moves steering column and mirrors . Any Suggestions ?
Old Feb 20, 2014 | 09:59 PM
mikebaker3's Avatar
Try doing a hard reset. The seat has a control unit under the front of the seat. Since all you did was replace the battery, try that first. Disconnect the ground lead (-) at the battery and touch it to the positive for about five seconds. That will discharge any capacitors in the seat control unit and then reconnect the ground cable to the battery.
Did that help?
Old Feb 21, 2014 | 05:48 AM
OldMike's Avatar
Are you saying that the seat won't move with the controls on the side of the seat or it just doesn't work automatically? If the latter, try moving the seat with the controls and set the preset position with the buttons on the armrest and see if that help. My 03 XJ8 is a bit quirky and sometimes stops automatically adjusting the seat bit it will start working again if I do what I just posted.
If it's the former, and if a hard reset doesn't work, it could be the control unit under the seat.
Old Feb 21, 2014 | 08:23 AM
Brutal's Avatar
both exact recommendations and what I would do. and if neither work drop the modules from both front seats and plug in the pass seat module to the driver. If it works you need a new seat module(and programming or youll have a PECUS fail message) and it was coincidental with the battery replacement
Old Feb 21, 2014 | 02:24 PM
h-barnes's Avatar
Hard reset ? All I could see happening with just negative disconnected and holding it to positive is fireworks
Old Feb 21, 2014 | 02:44 PM
Brutal's Avatar
Originally Posted by h-barnes
hard reset ? All i could see happening with just negative disconnected and holding it to positive is fireworks
not if you dont have a connection to the negative terminal on the battery. You dont have a complete circuit so no fireworks. But you do have a path to ground to discharge capacitors on the cars computers to erase volatile memory. This is just like rebooting you pc or laptop. Only a car does not have a restart or restore button.
Old Mar 1, 2014 | 02:23 PM
h-barnes's Avatar
It was the module that caused the problem or maybe because the module has Ford stamped on it lol
Bcrary3
Sep 12, 2021 05:41 AM
GordoCatCar
Jan 2, 2017 01:10 PM
corysansburn
Sep 10, 2015 06:15 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
Dallas XK8
Sep 3, 2015 12:17 PM
