Looking for a member to test my Icarsoft I 930 scanner
I'm looking for a fellow member with a 2003 XJR or XJ8 that I could mail my Icarsoft I 930 to for testing in order to find out if the unit's failure to communicate with my 2003 Jaguar x308 XJR ECU is because of the tester or my car. What's weird here is that this tester when loaded with OBD II software will work with other makes of cars no problem but for some reason it WILL NOT communicate with my car's ECU. It DOES communicate with all the modules" on the "CAN BUS" but not with the ECU which is on the SERIAL BUS. I originally bought this tester( $120) to trouble shoot an ABS (module) problem which it successfully accomplished. I am currently trying to troubleshoot "fuel trim" problems which without ECU communications is not possible
I make this request as Icarsoft has ZERO tech support or product support of any kind, My proposal would be to mail my tester to you including return postage and any fee that you would deem appropriate for your time to test the scanner. If it does work on your car that would say that the problems is probably with my Jag although other scanners work on my car in OBDII no problem. I have always suspected a "timing " problem with the Icarsoft software but confirming this with a company with ZERO support for its products makes this impossible. If the tester DOES work with your car perhaps you might be interested in buying it half price as it won't serve my purposes finding my fuel trim problems.. Your call. In keeping with rules to keep this excellent forum free of clutter , please email to me off line ( rjsimmons@rcn.com) if you can help me out with this. Many thanks for replies Ron Simmons Natick , Ma |
In the meantime it may well be that an elm327 for about $10 will let you look at trims.
Yep, my 7 euro bluetooth obd and torque does all trims perfectly well,
i have also tried icarsoft and it was utter junk, it was not able to connect to SRS for which i bought that thing, all readings were flipping values more fast than i could notice, for my luck seller accepted the return |
I did see a video about the ELM327 that fried the ECU on youtube
I think xjack had a carsoft and changed it for a Foxwell |
Will try mongoose clone now so my foxwell is for sale.
Originally Posted by fmertz
(Post 2066257)
Basically, there are 3 options:
I use my JLR SDD system, two different versions on two cheap laptops, for more complete and more complicated functions that require a battery support system to maintain the correct voltage over an extended period where one is performing something like a height calibration on suspension. I originally had a cloned mangoose cable that bit the dust after less than a year. Now have a genuine pro cable. |
Sent you an email let me know if you want to come to Rhode Island only 45 minuets away
Many thanks Julian ! I replied to your email
Ron Simmons |
