More exciting performance news
Old Sep 2, 2011 | 12:24 AM
avos's Avatar
@Count Iblis,
The 4.2 SC range rover versions do have a different exhaust manifold, from the outside it is a bit camouflaged, but the inside looks like a triple y system. That particular engine has some more changes that would suggest that it could deliver more hp, but Land rover iirc kept the jaguar performance specs in the sales brochures. But now my question, have you been involved in this manifold? Or do you know who has? It would be interesting to hear what the measured effects where.
Old Sep 2, 2011 | 08:49 AM
Count Iblis's Avatar
The tri-Y or split log arrangement on the S/C engine, provided it is of sufficient sectional diameter for the volume throughput of exhuast gases will provide an appreciable gain, regardless of what power curve was claimed by Land Rover. The split log arrangement tends to favour low end torque most while lowering back pressure of the system will favour top end performance
Old Sep 2, 2011 | 08:51 AM
XJR-0220's Avatar
ud
ill take top end any day of the week well as long as Im not doin a tractor pull or such lol
Old Sep 2, 2011 | 11:36 AM
sparkenzap's Avatar
"ill take top end any day of the week"
You really need more than 150 mph top end? Hope you have better chassis stability than mine has.
Old Sep 2, 2011 | 11:54 AM
Sean B's Avatar
legend has it the R in standard form with the electronic limiter removed topped 200mph at MIRA, brave guy whoever did that!
Old Sep 2, 2011 | 12:51 PM
XJR-0220's Avatar
ud
Not top end meaning top speed you twit, TOP END aka the top of the RPM band 4000+ to redline which is what we are talking about here, the equal length headers will help in that area.
I am not one for trying to go 180mph
Old Sep 2, 2011 | 01:21 PM
avos's Avatar
Now who is implying I would , 180mph is of course not on my list either.
But 300km/h is, and I think 310 km/h would probably be about the max with my gearbox/diff ratio/tire setup. Unfortunately this is not allowed on the relative safe oval tracks I know as I don't have a racing license, but I luckily I could try this on the public road towards the track in germany , if I could only overcome the fact that there are people waiting for me at home .
So for now it's only the enjoyment of top end power range as mentiojned by xjr-0220 in lower gears
Old Sep 2, 2011 | 02:41 PM
  #28
XJR-0220's Avatar
ud
amen brother AMEN^^^^^^^^^^^^^^^
Old Sep 2, 2011 | 03:42 PM
sparkenzap's Avatar
Well, what you call top end power is NOT the only important parameter since the transmission is NOT continuously variable, and your engine is not always at top end. Peak dyno power at full rpm can only do good when the engine is running there. AND, unlike a Jaguar XJR, some tractor pullers DO have torque conversion that does alow the engine to run at the peak power point.
And, I hope the Europeans have more class than to even know what a tractor pull is!
Old Sep 2, 2011 | 06:22 PM
  #30
XJR-0220's Avatar
ud
No its not always in the top end but when Im racing I never drop below 4000 rpms so if I can make most my gains from something in the upper rpm band I will take that everytime as that will give me the most improvement in acceleration and 1/4 but I do have a nice cummins powered diesel that makes 670 hp and over 1000 rwtq if I want to play tractor hahaha
Old Sep 2, 2011 | 09:06 PM
  #31
SteveM's Avatar
Well, what you call top end power is NOT the only important parameter since the transmission is NOT continuously variable, and your engine is not always at top end. Peak dyno power at full rpm can only do good when the engine is running there. !
That's where the whole concept of downshifting comes in to play and all those gears in the transmission. You need higher rpm, downshift a gear or two and just like that, you're in top end power. The rpms don't fall below about 4k anyways during WOT acceleration.
Old Sep 2, 2011 | 11:24 PM
  #32
X300 style vehicles are notoriously unstable at high speed.
I've taken a few XJRs to Nardo and on the autobahn
Old Sep 3, 2011 | 03:55 PM
  #33
adam699's Avatar
I don't know if I'd want all the top end on these motors since they seem prone to spinning rod bearings.
Old Sep 3, 2011 | 04:21 PM
  #34
sparkenzap's Avatar
say, Adam. How did you determine that? There have been a few reports of that here, but they usually start with a question like "what happens if I find no oil on my dipstick?"
Old Sep 3, 2011 | 04:54 PM
  #35
XJR-0220's Avatar
ud
yeah these engines are not prone to spin bearings well unless not being taken care of properly.
Delta66
Oct 4, 2015 05:40 PM
Johncy2000
Oct 2, 2015 01:05 AM
DFW
Oct 1, 2015 07:22 PM
Glenn Barickman
Oct 1, 2015 04:09 PM
asleach2889
Oct 1, 2015 01:53 AM
