OBD 2 questions
Old Jan 9, 2024 | 03:09 PM
hispeed42's Avatar
Originally Posted by RandyS
Different tools for different folks, I guess. I have found that sometimes it's not what is displayed on the reader,
but the way it is displayed on the reader that helps various diagnostic processes.
That is a true statement. I've got several little issues going on, and since I'm now fully retired, I decided to start looking into them. All electrical issues, of course: the driver's door won't unlock any locks, but the passenger door and the master lock/unlock on the top panel of buttons will. The fuel gauge is erratic and has been for a long time. And I can't adjust the driver's seat memory. These issues kind of appear on the Autel; however, it says that the fuel gauge has an open circuit, but this comes from the instrument pack scan. I haven't done the full pin point test yet, but I'm starting to think that the problem is in I-pack because the last two times that I've had to do a hard reset the odometer reading has changed. The first time it went down 5k miles and the second time it went up 2k. The other two problems are the modules, which I'll do in the spring. Oh yea, the Autel also tells me from the I-pack that the "SCP (J1850) (+)" has a circuit fault. SCP is the Standard Corporate Protocol network and the J1850 is the circuit to the DLC.
So, yea; the tool tells you what has a problem and now go figure it out.
Old Feb 9, 2024 | 03:44 AM
ForTheLoveOfCars's Avatar
Originally Posted by RJ237
Check that the reader is using protocol ISO 9141-2.
RJ i noticed the reader is running 9141 but does not include the -2 in startup any ideas?
Old Feb 9, 2024 | 06:10 AM
RJ237's Avatar
Not a clue
Old Feb 9, 2024 | 06:53 AM
Not a clue
okay thank you maybe i have a ground issue could that cause this issue? I can recall the first time i plugged my scan tool in to the car i could get live data this was during the very cold time of the year i also suspect some water intrusion to the trunk area around the security and locking module ive got a new antenna gasket since it was only $2 and some E6000 water proofing glue for any suspect spots its clear so as not to disturb any paint work i suspect some other issues are coming from water intrusion ive noticed a fair amount of wetness in the trunk area towards the rear seats on the batteries side which of course is where all the electrical stuff connects to the fuse box and grounds out there for the neg battery cable
AttyDallas
Apr 9, 2022 04:14 AM
vdpnyc
Apr 29, 2019 10:36 AM
robtroxel
May 18, 2017 03:30 AM
XJPurr
62
Jan 20, 2017 05:39 PM
inlining
Oct 6, 2014 06:35 PM
