OBD 2 questions
So, yea; the tool tells you what has a problem and now go figure it out.
okay thank you maybe i have a ground issue could that cause this issue? I can recall the first time i plugged my scan tool in to the car i could get live data this was during the very cold time of the year i also suspect some water intrusion to the trunk area around the security and locking module ive got a new antenna gasket since it was only $2 and some E6000 water proofing glue for any suspect spots its clear so as not to disturb any paint work i suspect some other issues are coming from water intrusion ive noticed a fair amount of wetness in the trunk area towards the rear seats on the batteries side which of course is where all the electrical stuff connects to the fuse box and grounds out there for the neg battery cable
vdpnyc
Apr 29, 2019 10:36 AM
XJPurr
62
Jan 20, 2017 05:39 PM
