OBDII code reader blank screen
Old Jul 7, 2013 | 02:29 PM
Maninahat98's Avatar
Default OBDII code reader blank screen
I plugged my Autel CAN OBDII reader into the CAN connector, screen stayed blank even after the ignition was turned to 'on' - nothing on the screen at all. So, I could have a faulty reader (it's brand new, first time I used it) or I have no power/signal coming from the ECM? What do you think? Is there a simple test I can perform? Any fuses affecting the CAN connector? The car runs fine no issues, I just wanted to read codes/see if there were any, just because I had the tool..... any suggestions welcome. Thanks Allan
Old Jul 7, 2013 | 03:01 PM
sparkenzap's Avatar
The fuse that power the data port are fuse #3 in the LH heelboard and fuse #4 in the trunk. Oh, the boot to you!
Old Jul 7, 2013 | 03:03 PM
Jhartz's Avatar
Is the CAN connector the same as the OBDII socket?
Might take it back to store and have them demonstrate it.
Old Jul 7, 2013 | 03:25 PM
Jim, yes, I wasn't sure what to call it, it's the one in the drivers footwell near the transmission tunnel. Thanks Allan.
Old Jul 8, 2013 | 03:27 PM
Thank you sparkenzap, fuse #4 LH Healboard blown. Changed fuse, OBDII working now, no codes. I noticed that only MISFIRE, CCM, HO2S are READY, all the others are N/A...did I not wait long enough or is it likely that they are not supported on a 1998 XJ8? Thanks, Allan
Old Jul 8, 2013 | 04:42 PM
sparkenzap's Avatar
NA is not applicable.. All is well. You have a P1000, do you not?
Old Jul 8, 2013 | 04:51 PM
I got the message 'NO CODES'.....Allan
Old Jul 9, 2013 | 03:11 AM
sparkenzap's Avatar
As you see from my edit, I had the wrong code. Your scanner must ignore P1111, which means "Readiness done", because one or the other codes should be displayed.
Quoting from page 1 of the "DTC Summaries" JTIS section:
"The following less frequently performed tests are identified as incomplete:
• Module $51 (identifies EMS ECM)
Catalyst
Evaporative purge system
O2 Sensor
EGR system
Further confirmation of the System Readiness Test status is available by retrieving the logged DTCs.
If DTC P1000 is logged in memory, the on-board diagnostic tests have not been completed.
If DTC P1111 is logged in memory, all on-board diagnostic tests have been completed.
Old Sep 5, 2013 | 08:25 AM
davea9988's Avatar
Default help me please. :(
hi there, i hope so can help me, my scanner wont read my 98 x308 i have checked both fuses (1 in the boot and one behind the heal board) still with no luck, i get as far as it starts to read the code and then my scanner switches off and goes back to the start. also while i was at the the fuse board in the boot and 1 in engine bay, it looks like there is relays missing, can shead some light if there is ment to be anything in these slots? looks like 2 in the boot fuse board and 1 in the engine bay? hopefully there is pics included.
cheers dave
Attached Thumbnails OBDII code reader blank screen-img_0387.jpg   OBDII code reader blank screen-img_0386.jpg
Old Sep 5, 2013 | 12:16 PM
Dinger's Avatar
Depends what scannner you have. Some of the cheaper ones won't read Jag codes before 2001 in UK.
Old Sep 6, 2013 | 07:44 PM
Lear45's Avatar
auto enginuity works for my 98 XJ8 but I had to buy the Jaguar add on about $500 total. Does airbag warnings and a lot of jag specific items. Still cheaper than one dealer visit.
trosty
26
Dec 18, 2022 06:40 PM
Bcrary3
Sep 12, 2021 05:41 AM
Budgie123
Sep 24, 2015 08:43 PM
jagfool
Sep 14, 2015 07:50 PM
tberg
Sep 7, 2015 07:32 AM
