Xj8 Completly failed Rotor
Old 02-15-2009, 03:58 PM
Received 2,183 Likes on 1,355 Posts
you need to remove this screw it holds the rotors on during line assembly at the plant, now they use cheap rings on 2 studs. You may have to use a impact driver the you hit with a hammer to break loose, then knock the rotor off with a hammer, you might want to spray the hub with liquid wrench if rusty, and rotate the rotor by hand as youre hitting it to knock it off evenly...of course this is all assuming you and I are talking about the same thing
Old 02-15-2009, 10:32 PM
It may be just the plug which seals an access hole to the parking brake adjuster. If you stick a screwdriver in the slot is it made of rubber? If so it's just the plug. Remove it and back off the park brake adjuster as a rust ridge has mostlikely formed stopping the hub from coming off.
Old 02-16-2009, 08:27 AM
Yeah pics always help :d
dsnyder586
04-04-2019 02:38 PM
ym37tech
02-08-2016 01:04 PM
AtholC
09-09-2015 09:07 PM
handcuffsready
09-07-2015 01:02 PM
JagLove86
09-06-2015 10:36 PM
Quick Reply: Xj8 Completly failed Rotor
