P0447 Evap Emission Control System Vent Control Valve Circuit Open
Old Jun 2, 2012 | 04:25 PM
MR. CJ's Avatar
Default P0447 Evap Emission Control System Vent Control Valve Circuit Open
I recently started getting a check engine light for the following code:
I can clear the code, drive for 30 miles and eventually the code will come back on. It is even more of a problem if I clear the code, go for a short few miles drive, stop, turn off the car, and the check engine light will appear.
From some research, I heard that the canister close valve could be the culprit. This is the valve on the right rear underside of the car, attached to the charcoal canister. I replaced the valve with the same exact part # from a known good valve and I have the exact same problem.
What's next? I am not sure what other areas to look at? Any specific diagnostic I can do with a multimeter or something else?
Thank you, C.J.
Old Jun 6, 2012 | 11:22 PM
MR. CJ's Avatar
Any tips?
Old Jun 7, 2012 | 08:30 AM
motorcarman's Avatar
The ECM is not 'seeing' a complete electrical circuit for the CCV.
I assume you are talking about the 1999 XJ8?????
Here is the DTC guide
bob gauff
File Type: pdf
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Russ Graber
Feb 23, 2019 11:59 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
