Perplexed. … Car won’t start. 2000 VDP xj8 - Jaguar Forums - Jaguar Enthusiasts Forum
Go Back  Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models ( Modern ) > XJ XJ8 / XJR ( X308 )
Reload this Page >
Notices
Old 12-16-2017, 02:00 PM
Default Perplexed. … Car won’t start. 2000 VDP xj8
Problem only recently began. Appears to be flooding.
If I block open the air intake butterfly , it will attempt to start using the additional air flow, but again stalls and will not start in normal fashion.
My wife drove it short distance, and car refused to start, after being parked an hour.
New Bosch battery. New fuel pump & fuel filter (2 mo ago)
ANY IDEAS????
Here are fault codes, read with … iCarsoft Multi-system scanner i930 :
Engine control module (ECM): P1260 security input / theft detected
Instrument Pack module: B1201= fuel sender – circuit open, U1261=SCP (-) circuit failure
Driver door module: B1697=”fault code not in database”, =B1234 mirror switch invalid code,= U1135 Ignition status not obtained
Driver seat module: U1135 Ignition status not obtained / ECU communication fault
Passenger door module: B2322 Mirror drive out of range / up/down , and LF/RT
Passenger seat module: B1961 =seat drive / backrest recline out of range.
Body Processor Module: U1041= SCP vehicle speed signal / invalid or missing data, U2012= communication bus error / non SCP, B1595= ignition switch / invalid code
Security locking module: U1135 Ignition status not obtained, P0100= MAF circuit / MAF sensor, P20e2= “code fault not in database”
HISTORY of 2000 Vandenplas : 7 years ago, bought this low miles VDP from friend, who purchased it at insurance auction. (38,000 orig mi)
Thank you in advance, for your assistance....
Old 12-16-2017, 02:05 PM
Clear the DTC and try another key.
bob
The Following 2 Users Say Thank You to motorcarman For This Useful Post:
Don B (04-14-2018), LAjag (12-16-2017)
Old 12-16-2017, 02:54 PM
Only have one key... and 1 remote key fob.
Old 12-16-2017, 03:06 PM
Replacement key is a dealer only item, I imagine
Yes or No?
Old 12-16-2017, 03:39 PM
Only have one key and one remote fob.. No other keys.
Old 12-16-2017, 03:43 PM
To isolate problem, I have tried "clicking" remote to lock car... then clicking again "unlock" car security system, before attempting to start car.
Car gets spark. Acts as if "flooding" is the primary problem.
Thanks, motorcarman
Old 12-16-2017, 04:20 PM
If it is cranking and getting spark, then it is NOT the P1260 Key/KTM problem.
You are living dangerously only having ONE KEY!!!!
bob
The Following User Says Thank You to motorcarman For This Useful Post:
LAjag (12-16-2017)
Old 12-16-2017, 04:32 PM
Lady Penelope's Avatar
Put your finger on the fuel pump relay and feel for a 3 - 5 second commanded on for the initial fuel prime then back to off . Relay clicks back on ( 3rd click ) after the ECU sees engine rotation . Safety design . See page 36 , trunk relays
http://jagrepair.com/images/AutoRepa.../jagxj1998.pdf
Can try a " Hard Reset " of the ECU's after clearing codes at the parts store
The Following User Says Thank You to Lady Penelope For This Useful Post:
LAjag (12-16-2017)
Old 12-16-2017, 05:53 PM
Sounds like bore wash could be a possible cause.
Old 12-16-2017, 06:13 PM
Robman25's Avatar
Could be bore wash but OP said that the wife drove for a short distance, I wonder if flooring the accelerator pedal might be worth a try?
The Following User Says Thank You to Robman25 For This Useful Post:
LAjag (12-16-2017)
Old 12-16-2017, 07:33 PM
http://www.jagrepair.com/images/Elec...al%20Guide.pdf
X308 Seats are 2 wire hall effect sensors different then the X300 3 wire potentiometers , Editing
Attached Thumbnails -x308-2004-seats-untitled.png   -x308-2004-front-seat-ecu-untitled.png
LAjag (12-16-2017)
Old 12-16-2017, 07:45 PM
If she drove for a very short distance it could be bore wash. First check the schraeder valve for fuel pressure. If yes, try flooring it and turn over for a few 10 sec bursts to get oil on cylinder walls, then back off to part throttle and see if it starts.
Old 12-16-2017, 07:47 PM
Default Question to all:
Engine wash not likely cause --- wife had been driving Jag, prior to being parked on level ground for 1 hr.
Sunny day when parked, dry day. no dampness.
QUESTION TO ALL:
Would "blocking open" intake butterfly cause ECM or PCM to change settings?
Don't believe so. However, I would like to hear from Jag experts or experienced mechanics.
In testing to determine if engine was "flooding", I cranked engine with butterfly blocked open (plastic screwdriver handle) in intake throttle unit. to maximize air inflow.
Engine immediately "kicked over" & tried to start, but would not continue.
Old 12-16-2017, 07:54 PM
Good idea ...except only have one key.
Dealer item I imagine
Old 12-17-2017, 08:18 AM
Sean B's Avatar
Jamming an electronic throttle body open with a screwdriver? I'd suggest you don't do any more of that as they have very sensitive sensors attached that are connected to the ECM via the Can Bus and will not run the car if it senses a fault by reading the position of the throttle plate...
petrol wash....100% have you even looked at the plugs??
Old 12-17-2017, 07:38 PM
Bore wash is flooding due to shutting off cold engine, has nothing to do with water.
Old 12-18-2017, 01:51 AM
Doesn't have to be flooding so much as lack of compression due to fuel washing oil away, but overall same outcome.
Old 12-18-2017, 06:46 AM
I didn't word that very well, you have it right.
Old 12-18-2017, 04:32 PM
Where can I post my problem about 2000 Jaguar Vandenplas not srarting after I ran the engine for only 30 seconds?
Old 12-18-2017, 05:29 PM
Sean B's Avatar
Jerry the subject has been covered to death basically 2 things you can try.
First is the flat floor throttle pedal start, as suggested by RJ further up.
Second is pull the plugs on the easiest side and see if they're wet and you smell fuel leave it to gas off, maybe overnight.
Then a teaspoon of engine oil down the bores.
You can try just one side first as some have and it may start, but both sides of the engine should get it up and running again.
Quick Reply: Perplexed. … Car won’t start. 2000 VDP xj8
Advertising
Featured Sponsors
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
