power steering leak. 2001XJ8
so what is the usual culprit? The hose or the reservoir?
It was the hose on my 2001.
On the XK8 it's usually the low pressure hose connection to the reservoir, and I expect the XJ8 is the same.
Originally Posted by 2001 White XJ8
(Post 2189875)
Yes, pretty sure it is. I will look in my records and see where I got mine.
I bought mine from Terry's and it was the High Pressure hose part number MNC3985AH. Mine failed 1.5 years ago with 145K miles on her. I had no problems with installation.
(Post 2190544)
Think I found it. Is it in Kalamazoo? |
(Post 2190544)
Is this the hose? |
No, is that what comes up under that part number. From my memory it was a combination of rubber and hard line.
(Post 2190709)
I need the low pressure hose from the reservoir to the pump |
Originally Posted by Gasworksgarage
(Post 2190721)
