question about this coolant hose
hey I'm getting a leak from this coolant hose right where the connector piece is, I don't see any hole or anything but it is leaking like small drips every second not sure why.
https://cimg7.ibsrv.net/gimg/www.jag...fe4e96510a.jpg it was leaking right there in the middle where the piece holds each hose together https://cimg4.ibsrv.net/gimg/www.jag...37cdf817e5.jpg here's better picture the hose runs somewhere along to the radiator |
heres another picture of where the hose comes from
https://cimg5.ibsrv.net/gimg/www.jag...b05875031b.jpg
also wondering if anyone knows the exact name of the hose just in case I need to buy another one |
There are o rings inside. You’d have to take them out and match it up. Ace hardware might have one? In a last ditch effort, I’ve also used some rtv on the o rings and let it dry overnight. Don’t be surprised if you’re taking that apart and it breaks. After all, it is old plastic.
That is the coolant bleed pipe coming off of the intercooler radiator and going to the expansion tank. |
Originally Posted by Addicted2boost
(Post 2487863)
also how do I remove the piece that the o ring is inside of
question
is this the o ring I need heres a screenshot it's number 14 on the diagram
https://cimg6.ibsrv.net/gimg/www.jag...13144b3091.png |
Originally Posted by mott
(Post 2487865)
question
ok is the o ring here ?
https://cimg5.ibsrv.net/gimg/www.jag...bc526019bb.jpg is it this where the o ring is inside of or is it the one on the first picture I sent |
question
o is the oring here
https://cimg2.ibsrv.net/gimg/www.jag...fdbe1b8e68.jpg just trying to make sure I put it in the right place is it this piece of the piece that goes to the overflow tank(reservoir) |
(Post 2487867)
https://cimg1.ibsrv.net/gimg/www.jag...fa7176419a.jpg |
CORRECTION: The shown #19 o-ring is at the expansion tank, not at the in-line connector. The inline connector is not shown on the above diagram but it is where the break is shown in the pipe #18. The 0-ring for the in-line connector may be different size than #19, not clear as it is not shown. Perhaps you can check with the supplier whether #19 can be used in the in-line connector. Take note that there are 2 o-rings in each of these connectors.
question
o ok thx so one is at each end of the hose
Originally Posted by M. Stojanovic
(Post 2488130)
