Removal of center console--2003 Jaguar xj8
Hi again,
I have a 2003 Jaguar XJ8. How do I removal center console? I don't see any screws or bolts. George |
RE: Removal of center console--2003 Jaguar xj8
put in neutral remove j gate surround.. carefully or it will brake.. then once off.. two 7 mm nuts and two 7 mm bolts..then remove plastic black surround and unplug sport switch..then pop wood out carefully.. then the wood around the center vent needs to be popped offabove radiothen remove2 torqs.. then at the back of the center console.. there is a vent.. pop it out with and unplug any connectors.. then remove 2 more torqs then slide console back and out.. then unplug ashtray connector..thens its off.
