Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ8 / XJR ( X308 ) (https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/)
-   -   Removal of Wood Covering Passenger Airbag (https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/removal-wood-covering-passenger-airbag-76930/)
Moe-she-sa Jul 16, 2012 11:59 PM
How do you remove the wood panel covering the passenger side airbag? I need to change the center vent. The wood panel that surrounds the center vent easily popped off. I was told that the wood panel covering the passenger side airbag should pop out in the same manner. I'm afraid to pull too hard for fear of damaging the wood panel.
Please advise!
Sean B Jul 17, 2012 04:58 AM
keep tugging, it should just pop off, it also has 2 fabric catch loops to hang from attached to the inner dash. Replace the clips onto the wood panel before installing back.
JaguarXJR02 Jul 17, 2012 07:28 AM
I would also disconnect battery due to airbag dangers
Moe-she-sa Jul 17, 2012 11:10 PM
Thanks guys! I will follow both of your suggestions.
dgr Apr 29, 2018 02:06 PM
Revisiting Wood Dash/Airbag
Hi Sean/Everyone,
I am replacing the wood dash over the airbag, and was able to get the old one off without issue. It looks like you need to remove the airbag to attach the bracket with the straps to the inner dash. Is that correct, or is there a way to remove the straps on the dash piece?
Thanks for any advice/thoughts.
DGR 200 XKR
Sean B Apr 30, 2018 04:29 AM
Yep, bag removal to attach the bracket, it's a bit of a faff, but it's a safety feature.
© 2026 MH Sub I, LLC dba Internet Brands
