Rotor Removal bolt - never seen this
Old Jul 28, 2016 | 08:39 AM
ReluctantMechanic's Avatar
Default Rotor Removal bolt - never seen this
Does anyone know where to get a tool for this? I really prefer not to drill it out or put in a shop for a rotor/brake job.Thanks
Attached Thumbnails Rotor Removal bolt - never seen this-rotor-retaining-bolt-02-xjr.jpg
Old Jul 28, 2016 | 08:45 AM
avern1's Avatar
It would be most helpful if we knew what vehicle you are working on. What it is you are attempting to do. Where the rotor is located on the vehicle.
Offhand that looks like a locating dowel and not a fastener, but without the above info we all would be guessing.
Old Jul 28, 2016 | 09:24 AM
How embarrassing - its the port cover for the parking brake adjustment. I did not see it in the barke protion of my FSM, but its inthe parking brake area. Sorry men
Old Jul 28, 2016 | 09:26 AM
Highhorse's Avatar
Hey avern1, I believe that is the rear hub, I think its the retaining pin. Like you said, we'd be guessing.
Reluctantmechanic, have you remove the rotor/hub from the spindle to see what it was?
Old Jul 28, 2016 | 10:09 AM
Again guys, my mistake. This standard rotor (non-brembo) does not have a retaining bolt on the rear - 2002 XJR standard brakes. What i encountered was the port to the parking brake adjuster.
Old Jul 28, 2016 | 10:24 AM
Mikey's Avatar
It's been a long time since I've seen so much corrosion on the wheel retaining studs. You're lucky that none of them snapped during lug nut removal.
Roger Mabry
Aug 10, 2021 11:51 AM
LeLimoMan
Aug 26, 2016 10:04 AM
stmcknig
General Tech Help
Jul 25, 2016 10:28 PM
Agent 00714
Jul 9, 2016 02:39 PM
Johnny V
Jul 3, 2016 11:29 AM
