Size of backseat door opening
Hi everyone, I own a 1998 LWB x308 and I have to pick up two chair frames with size W77xD70xH67cm and was wondering if this will fit throught the backseat doors (or ar least one of them). Does any one know the largest cube that will fit through that door? Thank you for helping me out. |
I can only do what you can do and and that is measure the opening of my rear doors, but an item of your measurements should fit fairly easily inside the back seat of your LWB. If there is any difficulty at all it would be possible initial interference with the rear of the front seat when angling the item in, but the front seat could be temporarily moved forward for clearance.
It's too big to go in the trunk/boot. My bet is you would not have any problem fitting it in the rear seat area.. |
I was just wondering if this kind of information was readily available. My car is parked in a garage away from home and so tomorrow I will get the tapemeasure out just to make sure. Anyway,thank you for answering. |
Originally Posted by Laurens1959
(Post 2015700)
