Starting problem + Losing my lights
I have a 4 litre Daimler Vanden Plas -98.
Sometimes, when I want to start the car, the lights next to the gearshifter is blinking red and when I put the key into the ignition, the steering wheel and chair does not move as they normally would. The lights come on as usual, but when I turn the ignition, everything gets black. The headlights will not turn on. The last time this happened, I opened the glove compartment and when I closed it, the car started.... A couple of years ago I changed the main grounding cable and looked over all the connections from the battery to the false bulkhead. Also, a few times, while driving, I have lost the headlights and at the same time, the red light indicating that I am not using my safety belt, comes on. The last time this happened, I turned the lights on and off a few times and then it worked. One time, I was picking up my letters in the mailbox and when I got back into the car, I could not get it into drive. After a little while, it worked. Any suggestions? |
Ground from the body control module, which is located behind the glove box. I had a similar thing, solved by running a separate ground from the BCM down to the gearbox. Therew is a thread about it on here somewhere.
Will look at it.
thanks Frode |
Nigelmay!
What you describe as BCM, is that what Jaguar call Body Processor Module? thanks frode |
Sorry, wrong terminology, it's the body processor module. Although it's bolted to the body with three fixings, on mine there was an intermitent ground that caused all sorts of issues: wiper doing a half sweep and stopping in the middle of the screen, losing all lights and indicators etc. etc.
thanks
Thanks for your reply. My English is not 100% so I got a little confused and therefor looked in the Jag manual.
frode |
Hi Nigelmay!
I am a bit afraid to do this myself so I went to see my garage today. They say they will do it, but asked for a specific point to connect the new grounding cable. Is there such a place ( a grounding point?) or do you just connect the BPM anywhere with a ground cable to the gearbox? Am I right when I assume this is not a job for a near-beginner? (Myself) I once had a Land-Rover and I got a book about how to do most the work on the engine. I used the book and changed all bearings etc in the engine. Is there something similar for my car? best Frode |
From memory, a ground strap was run from one of the three bolts that attach the BPM to the metalwork of the dashboard down to a convenient bolt on the gearbox. I don't think there was any need to chose a particular bolt, it was just to amke sure that the BPM had a good ground.
Originally Posted by nigelmay
(Post 1608997)
OK Thanks frode |
