Stereo
Old 07-23-2017, 03:28 AM
Pakmandog's Avatar
Default Stereo
Has anyone upgraded head unit thanks
Old 07-23-2017, 08:03 AM
King Charles's Avatar
Received 1,019 Likes on 740 Posts
Several threads here detailing options, use the search function.
Good luck !
Pakmandog (07-23-2017)
Old 07-23-2017, 12:46 PM
Milowokie's Avatar
I did, replacing the standard unit with a single DIN replacement is a lot easier than replacing the 'premium' system (speakers in A-pillars and parcel shelf).
Double DIN units are a lot harder, as they don't fit in the space behind the original unit with chopping and cutting at the car's structure.
I cheated and put a single DIN-chassis model with a double DIN display in mine, but they aren't cheap (and I needed an amplifier to replace the Jag unit in the boot).
https://www.jaguarforums.com/forum/a...cement-155873/
https://www.jaguarforums.com/forum/x...-radio-155898/
https://www.jaguarforums.com/forum/x...stereo-154456/
It's a damn sight easier if you have the correct wiring diagrams for your car, the system changed from HK to Alpine, my 1998 electrical diagram was no use on my 2000 car.
The standard system has power and speaker output in one white plug, as it drives the speakers from its internal amp. The premium just has the power connectors as line out signals go through a yellow plug to the amp in the boot and then to the speakers.
Oddly enough the actual stereo unit has a standard/premium switch on the case, I guess to select output levels for an external or internal amp.
As suggested earlier more expert opinion than mine can be found using the search function.
Good "look".
The following 2 users liked this post by Milowokie:
Don B (07-23-2017), Pakmandog (07-23-2017)
Old 07-23-2017, 09:41 PM
aquifer's Avatar
I did this about a year ago. What made it work was the shallow depth of the Alpine iLX-007 head unit. Just the other day I bought the new iLX-107, which was just released. It introduces wireless CarPlay, which is very nice. The 107 chassis is quite different than the 007, but it's still more shallow than a comparable single din, so it fit right in. Wiring harness is (fortunately) the same so I was able to do a fairly easy swap.
Not sure how to link, but I'll try:
https://www.jaguarforums.com/forum/x...pgrade-164822/
Edited to add for your amusement....you can install a startup bitmap on the Alpine, so here's what I did:
Old 07-24-2017, 12:43 AM
Pakmandog's Avatar
Thanks great job I will be doing mine soon
Old 07-24-2017, 02:11 AM
daverb's Avatar
Nice Job, did you make the surround or purchase. if purchased were from? I will be doing mine as soon as the weather cools down out here as you already know
Old 07-24-2017, 03:04 AM
Went w/ Kenwood DPX501BT & Rockford Fosgate P165 6.5" speakers here & am very pleased. Professionally installed so I can't help w/ schematics.
Old 07-24-2017, 12:02 PM
aquifer's Avatar
I found it on ebay. It was a single din, but I had it modified professionally for double din height, and tilted slightly for a better angle. I think they used Lexan (?) to create the new shape. I don't know much about shaping plastic like that, which is why I had much of it done professionally.
daverb (07-25-2017)
Old 07-25-2017, 12:38 AM
VR6Guru's Avatar
BUMP
Good too see these in one thread. I have searched this subject tirelessly but it seems to be a complicated task. There are a few single din units out there that seem to have a period correct look.
check this out.
https://www.bergvillfx.com/index.php...7418ub-or.html
Also anyone ever try this unit? seems to be shallow enough.
https://www.parrot.com/us/car-kits/p...asteroid-smart
Old 07-25-2017, 01:18 AM
daverb's Avatar
Thanks, will check that one out and see what else is out have found one other, now if only the heat would leave us
sayhitobaldy
E type ( XK-E )
02-01-2021 07:34 PM
Mark Hughes
05-14-2017 06:16 AM
dsd
05-12-2017 12:51 PM
Maximillion
05-12-2017 05:05 AM
nicholascdn
XE ( X760 )
05-10-2017 10:07 AM
Quick Reply: Stereo
