Supercharger Belt wont go on
Old Jan 23, 2015 | 04:02 PM
mustangtyson's Avatar
Question Supercharger Belt wont go on
I have had my XJR apart for a while and i cant get the supercharger belt on. Its almost like the belt has shrunk while it was off the car. Is there any trick to stretching it out so it will go on? I have the tensioner as far as it will go with no avail. It is a gates belt.
Old Jan 23, 2015 | 04:09 PM
hnatten's Avatar
It should go on quite easy. Make sure you routed the belt correctly around the crank and idler.
Drive Belt-Supercharger - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Heritage Parts UK
Old Jan 23, 2015 | 04:34 PM
looks cool. But i should not need something like this since i have a tensioner.
Old Jan 23, 2015 | 04:35 PM
Mark SF's Avatar
I remember mine being quite tight, even with the tensioner fully released. I used a 3 ft extension on the tensioner, making it easier to release, which helps a bit.
Try starting with the belt fully seated on all the pulleys except the top supercharger one, then work the belt around that with the tensioner released.
Old Jan 23, 2015 | 05:53 PM
rocklandjag's Avatar
There should be plenty of slack to slip it over the supercharger pulley. I use a 2' breaker bar but need to persuade it to clear the back of the fan housing.
Old Jan 23, 2015 | 08:20 PM
motorcarman's Avatar
If you have the original poly-groove and smooth sided belt then you should route the belt around all the pulleys except the smooth IDLER. Then slip the belt over the IDLER LAST.
bob gauff
MrWhite
19
Jun 14, 2022 07:49 PM
inactualis
Oct 2, 2015 11:13 AM
Johncy2000
Oct 2, 2015 01:05 AM
Col. Sandurz
Sep 28, 2015 07:29 PM
