Supercharger out, coolant lines in
Old Oct 20, 2014 | 01:28 PM
dsnyder586's Avatar
Default Supercharger out, coolant lines in
Hey all,
I am going through the valley hose replacement in my daughter's XJR (used to be mine) and wondered- do I need to replace the fuel line hose at the front? It looks rubber, but is it metal underneath? I don't want to remove the S/C twice because it leaks... it hasn't leaked so far.
Old Oct 20, 2014 | 05:47 PM
dsnyder586's Avatar
It connects to the injector rails and goes under the front of the S/C.... Anyone?
Old Oct 20, 2014 | 06:28 PM
plums's Avatar
JTIS calls it a crossover "pipe".
Never heard of it leaking.
Is there any flex at all to indicate it is a hose rather than hard pipe?
See 303-04 in JTIS because it is also referenced in 310-xx. The 303-04 section has better pictures showing the end fitting which is a flange and seal.
Old Oct 20, 2014 | 06:30 PM
dsnyder586's Avatar
No, it just made a slight crackling noise- which could either be a crack, or just the outer part being dry and brittle.
This job is a BEAR the first time, but I can see how it would be faster the next.
Old Oct 20, 2014 | 07:01 PM
plums's Avatar
Which job? Getting the pipe off or the sc+hoses?
Old Oct 20, 2014 | 11:19 PM
dsnyder586's Avatar
Getting the S/C and hoses R&R'd, although I am glad I slept on it and decided to take off the intake bypass instead of trying to get a wrench in there!!! (Which was my initial plan)
silkcat
Jan 18, 2025 04:29 AM
mrplow58
Jan 21, 2024 05:53 AM
Wahooesprit
Dec 23, 2019 02:01 PM
jimmiejag
Sep 9, 2015 02:56 PM
