Tips for remvoing stuck valve covers (cam covers)?
I'm trying to get my valve covers off but it appears they are "glued" on by the the old gasket maker. I don't reall have room to get a blad in between to cut the gasket maker apart, and I'd also be wored about scoring the machined surface.
Any one else experience this? Got any tips? |
Are you absolutely sure that all 14 bolts (12 parimeter 2 in center) are loose?? Those 2 center ones are a little bit hidden. If they are all loose but still not letting loose, I'd maybe tighten at least the 2 centers, loosely install the coils and run the engine to operating temp at idle to see if the heat releases them.
Originally Posted by Addicted2boost
(Post 1520038)
Can't idle the engine, no coolant, no oil and intake off and supercharger is halfway off. |
Originally Posted by OUScooby
(Post 1520071)
Yes got all 12 outer bolts, and the two in the center.
I would use a type of putty knife or very flat and wide tool of some sort to carefully cavitate the gasket inward to try and break the silicone seal.
The gaskets do not call for RTV except the little dabs in the front.
If you are sure that all the fasteners have been removed, a smart thump sideways with the side of your fist usually does it. You don't say how many miles or even what year, so it is pointless to speculate about accumulated varnish. |
Originally Posted by Johnny_B
(Post 1520074)
In that case, maybe careful use of a heat gun would do the same thing?
(Post 1520075)
Originally Posted by plums
(Post 1520099)
I gave a little loving nudge with a rubber mallet. They then came right off.
They should come off easily.
You have missed a fastener, find it before you break the cover trying to get it off. Vector |
Originally Posted by Vector
(Post 1520141)
You have missed a fastener, find it before you break the cover trying to get it off. Vector I feel silly, but its off now. |
(Post 1520472)
I did, the two under that bracket holding the wiring in place. I removed the two small nuts holding the bracket on, but then didn't remove the two nuts underneath holding the cam cover on.
I feel silly, but its off now. Now I can tell you: I was going for the crowbar when I decided to take one more look for fasteners, found one I had missed and off it came, easy as can be. Vector |
wrong post
