Transmission dipstick
Old Dec 11, 2025 | 11:59 AM
Ant305's Avatar
Default Transmission dipstick
Today i received my transmission dipstick but when i went to use it, it stuck out about 2 feet
and the end was dry.
Am I doing it wrong?
Is this the wrong dipstick?
Old Dec 11, 2025 | 12:06 PM
motorcarman's Avatar
The dipstick is a TOOL, NOT a car part.
The tool will check the level on all the cars/trucks that use the gearbox, not just Jaguars.
Refit the dipstick cap when you are done checking and put the tool AWAY.
Old Dec 11, 2025 | 12:07 PM
Ant305's Avatar
So when it bottoms out there should be liquid on there?
As I said it was dry when I took it out. Before and after driving the car.
Old Dec 11, 2025 | 01:41 PM
The tool seems to get stuck in a few places along the way to the stop in the pan area.
Keep 'stabbing' the dipstick up and down while turning the handle to get past any turns and tube obstructions.
When I finally get mine to 'bottom' I mark the stick for my cars so I know when I get to the proper measure point.
Old Dec 12, 2025 | 11:56 AM
Hooli's Avatar
Isn't there something about checking the level when running & warm? or is that just for the level plug & the dipstick works when cold & off?
I knew once, but after buying the dipstick I've never got around to using it so forgotten the details.
Old Dec 12, 2025 | 12:44 PM
There are HOT and COLD markings on the stick.
Accurate readings are probably HOT but cold can give you a quick level indication.
Old Dec 13, 2025 | 04:18 AM
Hooli's Avatar
Cheers.
GGJag
Dec 8, 2024 03:36 PM
Jose
17
Oct 2, 2023 06:38 PM
MK2 1962
16
Oct 15, 2021 03:50 AM
JaguarXKR
Sep 13, 2020 09:16 PM
switchspencer
Jun 27, 2011 02:38 AM
