Ultra High performance tires?
Hey Gents,
looking at a new set of shoes for the Jag. The size thats on there now is 255 45 18. I'm noticing that most ultra high performance/track tires only come in 255 35 18. What do you think about a shorter sidewall? Could I fit anything wider like 265's on there? These ones are 255 40 18. liking the the Yokohama advan's Tire Search Results Any feedback or advice always appreciated. Thanks! |
PROXES R1R Extreme Performance Summer Tires | Toyo Tires
Or these but they are only available in a 255 35. |
after this i'll shut up i promise. Hankook Rs-3 and Dunlop Durezza Star Spec. This car is not a daily driver btw. Cheers!
Well the stock size is supposed to be 255/40/18 so you can start from there.
Originally Posted by Thundercat
(Post 354730)
But, how are you liking them? They fill the wheel well quite nicely as they are slightly larger in diameter. Toyo's are, and have a reputation for being noisy. |
(Post 354730)
Hey Gents,
looking at a new set of shoes for the Jag. The size thats on there now is 255 45 18. I'm noticing that most ultra high performance/track tires only come in 255 35 18. What do you think about a shorter sidewall? Could I fit anything wider like 265's on there? These ones are 255 40 18. liking the the Yokohama advan's Tire Search Results Any feedback or advice always appreciated. Thanks! Do your tires rub at all? I have 245/45/18 Contiental Contiextreme Contacts on my 2000 VDP and they rub just a little if I turn the wheel to the extreme left or right and run over a bump. It almost never happens though. |
Unless you are getting paid to drive your car . . . fast . . . you are wasting your money on super high performance tires.
Look at some of the ratings and customer feedback at TireRack for far better investment of your hard earned bucks. |
Thanks. you guys are champs. no rubbing. can i put a 265 on there? I would like to put some no BS tires on this thing as I drive only in the summer and the car is EXTREMELY powerful. I drive it MAYBE 5k per year. Lets consider this a price is no object kinda thing.
Originally Posted by test point
(Post 354828)
Look at some of the ratings and customer feedback at TireRack for far better investment of your hard earned bucks. Make sure you get some good tires though. My car came with Pirelli P6 tires that were absolute CRAP. They had weak wet and dry traction at the limit. It sounds like you are a performance driver? The prob with the Contientals is that the sidewalls are soft and can lead to rim damage on rough roads. Also, the tires are very quiet when they skid which can be a problem if you drive on a track and etc. They can give a false sense of having more traction than you really have. The Pirellis scream when they skid. Look for tires that scream when skidding if you are a track driver. I have a long wheel base XJ that is designed to understeer and plow in the corners. The sound of skidding to indicate understeer is pretty important when driving my car aggressively. Its great to see that you are upgrading your car. Too few people upgrade their XJRs. Has anyone been able to powerslide in a controlled manner in a XJ? I know that an open diff makes this pretty difficult. Its pretty hard to control my VDP in a powerslide. Its also close to impossible to get a VDP to even oversteer on a dry road without the throttle (actually I have never been able to do this at all). |
I'm assuming you have a 8" wide wheels. 265's are too wide for 8". Tire Rack has the recommended wheel widths for each tire size in the specs chart.
(Post 354844)
Does this go as far as buying new tires every two years?....'cuz that's probably what you'll be looking at with ultra high performance summer tires. You probably know that already but I had to throw it in :-) Cheers DD |
(Post 354844)
Originally Posted by SteveM
(Post 354855)
255 40 it is. Thanks gents. Cheers!
Originally Posted by burmaz
(Post 354851)
Originally Posted by plumsauce
(Post 354866)
hannnh?
I run 255/35/19's being an XJR100 it has the Montreal wheels. The car loves good tyres.
I've used Michelin Pilot Sport 2's to good effect, excellent dry tire. I'm now using Bridgestone Potenza RE50's, and these I find are even better in the dry. (I don't use the car in rain) I'd recommend these. Whatever, they'll have to be Y96 rated, extra load. Because of the size and speed of your car, use nothing less. Period. |
