V8 Valve lifter tip
Old May 24, 2017 | 08:54 AM
anton5678's Avatar
Default V8 Valve lifter tip
My 99 XJR blew a head gasket so when I had the heads off I thought I'd clean them up a bit, well I found out if you turn the head upside down the lifters will fall out thus loosing your valve lifter adjustments so to prevent that from happening I took some 3/4 inch plastic pipe and some O rings to keep them in place and installed them in the heads.
Attached Thumbnails V8 Valve lifter  tip-011-800x600-.jpg   V8 Valve lifter  tip-012-800x600-.jpg   V8 Valve lifter  tip-014-800x600-.jpg   V8 Valve lifter  tip-019-800x600-.jpg
Old May 24, 2017 | 09:34 AM
motorcarman's Avatar
That is the way I store and/or ship AJV8 heads if I remove the cams.
I have sold and shipped heads to someone that needs to install heads on a different 4.0 engine so the intake cam needs to be swapped. The exhaust cams can be used on all the 4.0 variants but the intakes are different (SC vs NA, AJ26/AJ27/AJ28).
A wood dowel rod can be used also.
bob
Old May 28, 2017 | 05:26 PM
Houseofpaincakes's Avatar
That's a very clever trick. Thanks for sharing it.
