Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ XJ8 / XJR ( X308 ) (https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/)
-   -   Weird steering noise @ low speeds (https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/weird-steering-noise-%40-low-speeds-75188/)
KevinWeisert Jun 16, 2012 03:45 AM
My 1998 VDP has been making a strange noise. About 20% of the time, @ low speeds when the wheel is turned most the way left or right, I hear a noise eminating from the front of the car that sounds odd. The best way to desrcibe this sound is this: In the US there's a board game called "the game of LIFE". In that game there's a spinwheel that clicks against a plastic pointer. Or like putting a playing card in your bicycle spokes. Is it a low brake fluid level causing the pump to suck air when the rack is fully cycled or could it be something else? Thanks for any info or help...
Sean B Jun 16, 2012 04:54 AM
There's an ABS ring that could have something catching on it that would give you the card in spokes sound. If you can get the car on a ramp or at least eyeball underneath, you may find the issue.
© 2026 MH Sub I, LLC dba Internet Brands
