Where does all the oil go?
Old Jul 5, 2013 | 08:32 PM
OldMike's Avatar
Default Where does all the oil go?
My XJ8 tends to use at least a quart of oil between changes which I do every 5,000 miles or so.
I don't see any drips on the garage floor, so where does it go? Does my car consume oil? If so, is that normal?
I do remember reading in the user manual that it's normal to add oil between changes, but how much is normal?
Old Jul 5, 2013 | 08:58 PM
sparkenzap's Avatar
OldMike:
You have a non Nikasil engine, so you need to watch what engine you are comparing your oil use experience to. My MY '02, XJ8, also a non Nikasil engine, uses about 1 qt between 10000 mile oil changes on Mobil 1 Synthetic. It has about 180,000 miles on the clock. MY XJRs (both of them are Nikasil engines) use less even though they have the same or more miles- I suspect it is the Nikasil. Some amount of oil passes the rings and is burned. Your oil use sounds like it is high normal.
How many miles are on the clock?
Old Jul 5, 2013 | 09:15 PM
Mikey's Avatar
1 qt per 5000 Km is nothing to worry about. If it were 1 per 500 Kms, I'd pay attention.
Old Jul 6, 2013 | 07:05 AM
OldMike's Avatar
I have just over 90k on the odo, and it's going through about 1 qt every 5k miles.
Old Jul 6, 2013 | 05:10 PM
Ipc838's Avatar
I change my oil at 3000mi ints, and I never lose more than .4qt per change
with the exception of the time I did a track day on my oil,
where I had consumed what seemed to be a over 1/2 qt on that next oil
change. 1qt per 5000 sounds normal enough for a quad-cam V8 in my opinion.
Old Jul 6, 2013 | 06:22 PM
OldMike's Avatar
I really appreciate all the input on this issue -- it gives me some peace of mind! I'll be changing the oil tomorrow eventhough I just put a quart in it yesterday -- probably put 100 miles on the car since then so it wasn't all for nothing.
MrWhite
19
Jun 14, 2022 07:49 PM
Dave1109971
Dec 15, 2015 06:16 PM
3jagfamily
Oct 1, 2015 01:49 AM
Woznaldo
Sep 26, 2015 11:02 AM
ahunt4
Sep 25, 2015 03:43 AM
