X308 Propshaft/Driveshaft center bearing info
  #61
Old 01-06-2019, 08:06 PM
Highhorse's Avatar
Received 1,766 Likes on 1,300 Posts
BW, I'm just up the road in E Orlando...I had Advance Driveline do mine. They're just off N John Young on the left side going N. You will have to go up to the light and do a U-turn at Edgewater. They do a lot of heavy driveshaft work, like for box trucks, which have similar driveshafts as the X308, so I bet they can do the U-joints quite easily also.
The following 2 users liked this post by Highhorse:
BW_Hunter (01-08-2019), Don B (01-06-2019)
  #62
Old 01-08-2019, 08:22 PM
BW_Hunter's Avatar
That’s great , thanks! I think I found the right ujoint...Jaguar part jlm823 aka guj108.i ordered one...it was pretty cheap. If it doesn’t work I’ll go to advanced....
that u-joint fits a lot of Land Rovers, several Rover cars, a bunch of Jags and, weirdly, a Volvo.....
Thanks again!
Carnival Kid (01-09-2019)
  #63
Old 01-09-2019, 09:49 AM
Highhorse's Avatar
Thanks again!
Ford also owned Volvo from 99-10....coincidence?...I think not...lol
  #64
Old 01-09-2019, 10:52 AM
M. Stojanovic's Avatar
Volvos of the 80's and until mid 90's (240, 740, 940) used the same UJ as the one we are talking about. By 99, there were no more Volvos with a propshaft, only FWD.
  #65
Old 01-09-2019, 08:36 PM
Highhorse's Avatar
What about AWD?
  #66
Old 01-09-2019, 09:03 PM
Carnival Kid's Avatar
Received 1,008 Likes on 613 Posts
Thank you BW and Euphonium, I have stored those part numbers for any possible future reference.
  #67
Old 01-10-2019, 05:20 AM
What about AWD?
Well, I meant the usual saloons. UJ-s, like bearings, are shared by many cars, trucks, vans, construction machines and what not. The info on UJ-s suitable for our X308-s is as follows (the sizes shown are cap diameter x UJ span, face to face of two opposite caps).
Propshaft:
Jag p/n GKN p/n Size (mm)
8405 --> U225 (27 x 81.7)
9409 --> U225
10065 --> U225
JLM823 --> U968 (27 x 81.7)
C10065 --> U100 (27 x 81.7) (for some reason, "C10065" shown in the GKN catalogue as Jaguar part no. does not exist on the current Jag parts websites)
Leyland p/n
GUJ108 --> GKN U225
GUJ104 --> GKN U225
GUJ105 --> GKN U225
GUJ117 --> GKN U225
You will note that GKN have their U968 for JLM823 and U225 for GUJ108 but the dimensions of the GKN U225, U968 and U100 are identical so all can be used.
Equivalent UJ-s from other manufacturers:
GMB 210-0153 (215-0153)
SKF UJ369 (SKF cataloge states for “Jaguar 1961-1985”)
Hardy Spicer: 3151-166W, K5-GB117, K5-GB166, K5-LGB104, K5-LGB128, K5-LGB133, K5-LGB166, K5-LGB74
TRW: 20049, 20208, 20306, 20335
There are also equivalent UJ-s from quite a number of other less popular manufacturers like Italcardano, Quinton Hazel, Toyo etc.
This size of UJ-s (GKN U225 or equivalents) is used in vehicles by: British Leyland, Land Rover, Jaguar, Triumph, Bedford, Chrysler, Mazda, Nissan, Toyota, Isuzu, Mitsubishi, Ford, GM, Volvo, Deutz, Fiat Iveco, Fiat Hitachi, International Harvester, Hyster forklifts, Case, Caterpillar, John Deere and Komatsu machines, Mack trucks, Massey Ferguson, ****** Jeep etc.
Half Shafts:
GKN U922
GMB 210-0160, 220-2050, 250-0130, G5-160X, GU-2050, GU-2050SL, GUA-13
SKF UJ330
The following 3 users liked this post by M. Stojanovic:
Don B (01-10-2019), Highhorse (01-10-2019), RetardeD2 (02-26-2021)
  #68
Old 01-10-2019, 07:15 PM
Looks like Rock Auto have very good prices for the X308 UJ-s:
The following 2 users liked this post by M. Stojanovic:
Don B (01-10-2019), Highhorse (01-11-2019)
  #69
Old 01-10-2019, 11:08 PM
Received 12,717 Likes on 6,372 Posts
M. Stojanovic,
Thank you for the excellent information! That's great research.
For those trying to decide which brand to purchase, GKN, GMB and SKF are all known Jaguar OEMs (Original Equipment Manufacturers). If I recall correctly, GMB is the Japan-based operation of GKN, the U.K.-based company that supplied many Jaguar differentials driveshafts/propshafts, and axles. SKF supplied wheel bearings to Jaguar (and other top-tier customers such as Rolls Royce and the Ferrari Formula One team). We probably can't go wrong with any of the parts you identified.
Cheers,
Don
  #70
Old 01-11-2019, 03:48 AM
Marcel de Vries's Avatar
It looks like these are for '85 XJ6 , or am i blind ?
Don B (01-12-2019)
  #71
Old 01-11-2019, 06:26 AM
These UJ-s were used on Jaguars starting from Mark 1 (1955) and (officially) up to 1997 (according to a GMB catalogue) meaning including the X300. I said "officially" because after X300, i.e. in the case of the X308, the UJ-s were no more a separate p/n (because they want you to buy the whole $$$$ propshaft). However, the X300 UJ, JLM11718, is not listed as a part number in any of the UJ catalogues I have, only one of the the GMB catalogues states "Jaguars up to 1997". Are X300 UJ-s same as the X308 ones?
  #72
Old 01-11-2019, 07:41 AM
"Are X300 UJ-s same as the X308 ones?"
I'm not sure , but found some info for the x308 ones :
"The central universal joint next to the rubber driveshaft mount measures 75mm cap to cap. The cap diameter is 27mm"
- Hardy Spicer K5-L4R (or K5-A757 heavy duty)
- GKN U110/L
- British Leyland GUJ116 (Triumph Stag)
NOTE: These are for the propshaft
Now the question , are the XJ and XJR u-joints different ?
I don't think so
Don B (01-12-2019)
  #73
Old 01-11-2019, 12:06 PM
nilanium's Avatar
Should be the same part for both the NA and SC cars.
I posted on this a while ago, got some info here as well to add to the parts mentioned. https://www.jaguarforums.com/forum/x...umbers-191468/
  #74
Old 01-11-2019, 10:15 PM
I have to make a CORRECTION to the info I posted earlier on the X308 Half Shaft UJ-s. What I showed in my post above for Half Shafts are UJ-s for Jaguars up to 1985, i.e. up to and including XJ6/12 S3. These UJ-s are 30.2 x 106.36.
The correct info for X308 is as follows:
X308 Half-Shaft UJ (30.2 x 92) JLM 1388
Old Jaguar p/n: ----> GKN
11682 ----------------> U220
7152 -----------------> U220
C11682 -------------> U220
Layland:
GUJ112 ------------> U220
The old Jaguar part numbers are not shown on the Barratt's website as superseded by JLM1388 but the UJ-s are identical size. So, the suitable X308 Half Shaft UJ-s are:
GMB.........250-0120, 210-0178, 210-0447
SKF..........UJ331
GKN.........U220
Spicer......1350
and, of course, many equivalents from other manufacturers.
Don B (01-12-2019), nilanium (09-28-2020)
  #75
Old 09-26-2020, 12:26 PM
hispeed42's Avatar
Here it is a year-and-a-half after the last post and I thought that an update to the center bearing would be useful. I'm in the middle of a project to replace a lot of stuff that hasn't been done since new which was 18 years and 178k+ miles ago; new motor mounts all the way around, fuel injectors cleaned an flow tested, new downpipes with 200-cell cats (had a cat rattle going on), etc. When I got the exhaust pipes off the old cats, I took a look at the driveshaft to see the condition of the center bearing. The picture tells the story:
I went to Power Train's website and the 3080-25 bearing is not listed anymore. I called them to see if there was an updated part number, which there is not; however, the gentleman that I was speaking with said he found "a few" at the Virginia Beach location. So, of course I ordered one along with the GAJ-1 Jurid Couplers. I also ordered a new UJ from SNG Barratt.
So, anyone planning on doing a driveshaft rebuild anytime soon and planning on using these parts should call Power Train's Virginia Beach location to get one of those "few" that are still available.
The following 3 users liked this post by hispeed42:
Carnival Kid (09-26-2020), Don B (09-26-2020), Highhorse (09-27-2020)
  #76
Old 09-26-2020, 06:58 PM
I bought the available X300 centre bearing EBC9040 (for spare, haven't fitted it). It has exactly the same dimensions as the Powertrain's 3080-25. Also bought the spline protective gaiter JLM1543.
EBC9040 & JLM1543
The following 5 users liked this post by M. Stojanovic:
Carnival Kid (09-26-2020), Don B (09-26-2020), Highhorse (09-27-2020), hispeed42 (09-27-2020), RetardeD2 (02-23-2021)
  #77
Old 09-27-2020, 11:07 AM
hispeed42's Avatar
Thanks for the part number for the gaitor; I hadn't come across that, yet.
  #78
Old 07-25-2021, 08:26 PM
ericjansen's Avatar
Received 1,351 Likes on 926 Posts
I have nothing to add, other than that it helped me tremendously in solving my XK8 bearing problem without buying a complete assembly.
Thanks to all posters in this thread, you rock!
https://www.jaguarforums.com/forum/x...8/#post2420815
The following 3 users liked this post by ericjansen:
Don B (07-25-2021), hispeed42 (07-26-2021), Jhartz (07-26-2021)
  #79
Old 11-10-2023, 08:56 PM
BRG'83xj's Avatar
Sorry to bring up an old thread but did you end up installing that center support bearing part #EBC9040? was it correct? I am trying source a center support bearing and Powertrain industries dont seem to be able to help me.
  #80
Old 11-11-2023, 10:35 AM
euphonium01's Avatar
Do you mean the centre drive shaft bearing? If so, yes I did. I have a UK contact for supplying one if you need it.
Paul
Quick Reply: X308 Propshaft/Driveshaft center bearing info
