X308 XJR no start after fuel pump and secondary tensioner replacement....
#41
#42
The starter motors on car engines draw current in the range of 300-500 A, more towards the upper figure in the case of our V8's (up to 1,000 A on diesel pick-up truck engines). With this kind of current draw, the battery voltage will (temporarily) drop significantly during cranking. It is, however, possible that the Jag ECU will not allow the engine to fire-up if the battery voltage is below 11.4 volts before attempting the engine cranking as, at this voltage, the battery has just some 15% charge and, whilst it may still crank the engine, its voltage drop during cranking would be so much that it would confuse much of the car's electronics.
#43
Been a while since an update. Just so you guys know the car is running again. Andy at Jaguar Doctor here in Orlando got it going. Turns out a wire somehow pulled out of the bottom of the front fusebox and 2 relays (ignition and injectors) were kinda hit or miss working sometime and not others. $230 bucks and we're on the road again. There's a couple issues to clear up (cylinder 5 misfire and that fuel return hose in the tank) but other than that we are 100%. Thanks for all the help
#45
The second hose, according to your description, appears to be part of the fuel return line. This is the line from the fuel pressure regulator that enters the tank near the fuel delivery line (the one to which the "Y" fitting is connected) and probably has a length of rubber hose connected to it inside the fuel tank. Does the hose you poked have one end free inside the tank? If so badly deteriorated, it will keep on releasing flakes/chunks of rubber that will clog the pump strainers again.
#46
I wouldn't worry about it as it is not really necessary. If you park the car for a month or so, just switch the ignition on and off a few times prior to cranking the engine and the fuel system will be primed well even if the fuel rails were completely empty.
#47
I don't know the Jag fuel circuit well at all, but the fuel pressure of 2.5 Bar almost has to be maintained by a back-pressure regulator somewhere between the rail and the tank. That regulator would keep fuel in the rail unless it won't close tight. Is this that valve?? Surely a cheap, crum version, if so
#48
Highhorse
02-20-2016 10:18 AM
GordoCatCar
08-02-2008 01:02 PM
