XJ8 1999 bonnet cable broken
Old 12-22-2014, 03:49 AM
ronstrutt's Avatar
Default XJ8 1999 bonnet cable broken
cable is not attached at latch under bonnet suspect broken. how do I get the bonnet up? drivers side.
Old 01-05-2015, 02:50 AM
GGG is online now
Received 16,792 Likes on 12,165 Posts
Welcome to the forum ronstrutt,
I've moved your question from XJ ( X305 ) XJ12 to X308 forum. Members here with the same model will be able to help.
Old 01-05-2015, 04:02 AM
jimlombardi's Avatar
Received 1,618 Likes on 874 Posts
Look at this thread (hood latch stuck):
https://www.jaguarforums.com/forum/x...-stuck-106016/
Jim Lombardi
Old 01-05-2015, 05:38 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
I would add that it is very helpful to have a look at another X-308 before going at it. Disconnect the battery before you start (make sure your key works or be damned sure to prop the boot up!) and then be careful to not get into the power cables located near the latch.
Old 01-06-2015, 07:10 PM
Lear45's Avatar
Take the wheel off and drill a 3/4" hole in the fender to allow using a screw driver to pop the latch. (find a plug first that will fill the hole. The exact size isn't critical). The hole will be closest to the latch in the wheel arch. Check other threads on the forum. They may explain it much better. Not really that bad. You can then remove the latch until you have time to repair it. Good Luck
49Markvman
E type ( XK-E )
09-21-2015 06:26 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
mhenz
09-14-2015 07:47 PM
AtholC
09-09-2015 09:07 PM
TexasCat
09-08-2015 04:36 AM
Quick Reply: XJ8 1999 bonnet cable broken
