XJR 100 Shocks
Hi all,
Please advise. It looks like it is time for some new shocks :/ I don't want to break the bank but I was thinking a bit more modern, any thoughts? Currently it is settling poorly along. PS. Do I need a specific shock do the the CATS suspension? |
I'm just going through this as well.
For the rears I got the the Bilsteins 20-070519 - this is the CATS version. They haven't arrived yet, they are back ordered. I was willing to wait as my car won't be driven till the spring and the ones I found were a pretty good deal - $311 each with free shipping (most places they are around $335 each). https://www.truckspring.com/Search.a...word=20-070519 Not sure about my fronts, I'm gonna swap out the bushings first and see what that does. Mine is a 2003 XJR. |
I think Bilstein USA offer refurbishment, I would certainly consider this,
From a prior post, the refurbishment was about 2/3 the cost of a replacement shock. You'll likely have to send yours in and wait though, so if you're unable to give up down time, then it might not work well. To answer your question, though, yes, the CATS shocks are specific. BILSTEIN 20070502 for the front which RockAuto has for about 271 at the moment. They are easy to swap out. The other option is to swap everything to standard shocks. You can get the Bilsteins normal versions (Non-CATS) for about 100 dollars a corner. You'll need new mounts since the shaft diameter is different than the CATS one, but you can get the new front upper mounts for usually 20-30 apiece, and if you're replacing the rear shocks, CATS or no, you should be replacing the uppers there too so it wouldn't be any different just to get the new mounts for the difference. You can also get KYB shocks for about half the price, but honestly, Bilsteins are the way to go. Can go for comfort or sport versions.
Thanks all. I think i'm leaning to billstein sport shocks.
I'll report back tomorrow, as I just put them on the front of mine this morning (replacing the blown out KYB ones - hence my recommendation to go Bilstein - the KYBs lasted 23k miles on the first set, and 21k on the 2nd set that was the warranty replacement, basically each set lasted a year). I'll let you know how they ride after I get to work tomorrow :)
Oh great! Looking forward to hearing back! Did you go for the sportier ones?
Originally Posted by jonathanelewis
(Post 2022749)
EDIT: Following up - I'm quite happy with the sports. They're firm when they need to be but not harsh or jarring, and still comfortable that you don't feel like there isn't any give to them. |
Originally Posted by CharlzO
(Post 2022817)
Yes, I went for the sport versions. I've always enjoyed a spirited ride, and while I wholeheartedly agree that a plush Jag should ride in cushy comfort with comfort shocks, I believe the XJR's slightly sportier nature was deserving appropriately sporty shocks!
(Post 2023733)
Thanks so much! I think i may go for these
Anti role bars front and rear, bushings, springs etc are all unique to the XJR. 100's are fitted with the 'SuperSports' suspension package. |
Are you saying go with the sports from billstein? Is there a super sports line that you're referring to ?
were these the ones? Do i need damptronic because of the CATS system?
https://www.bilstein.com/us/en/produ...64222107697812 https://www.bilstein.com/us/en/produ...64222107697812 |
Yes, they're the ones to fit.
Originally Posted by Sean B
(Post 2026949)
(Post 2026984)
thanks! Do I need to do anything to bypass the CATS system? Will the sport button stilll respond the same? |
