1989 vanderplus
I just got this 89 vanderplus it was sitting for 4 years I can’t find where to drain oil and the gas lever I’ve been using trunk emergeny switch I turn the car over but seem like no fuel is going in what should I do fuel pump??and also message curcuit 1 and 2 failure can someone help me? |
Just a point the ‘89 Vandenpla is called an XJ40 which is the previous series of XJ6 so this is the incorrect forum. |
And when you get to the right forum it is Vanden Plas...named after a famous coach builder.
If I had a dollar for every hillbilly on craigslist selling an x300 or an xj40 that called it a "vanderplus" and said it had a V6, well I probably wouldn't have to look for cars on craigslist.
Hi Andrew,
I have moved your thread from the forum for the X300 to the forum for the XJ40, which is the Jaguar factory project code for your 1989 Vanden Plas. Here you will find knowledgeable owners of similar cars who will be happy to try to help. You can help us help you by giving us more detail, with each topic separated by a period. A separate paragraph for each issue is even better. I'm not trying to scold you, it's just very difficult to interpret your issues when they are presented with so little detail and in one run-on sentence. Regarding the oil drain plug, it is on the rear end of the oil pan/sump, part 8 in the diagram below. Don't remove the oil relief valve plug, part 4 in the diagram, which is near the front end of the sump: https://cimg5.ibsrv.net/gimg/www.jag...a41021336b.png Regarding the Circuit 1 and Circuit 2 failures, I can't recall what those mean but they may indicate blown fuses. If you don't have the Driver's Manual (Owner's Manual) to look up the definitions of those messages, used copies are often available on eBay and Amazon. See the links below for a few resources that will get you started on your journey: Haynes Jaguar XJ40 Repair Manual (U.K edition missing chapters 7 and 8) Jag-Lovers XJ40 eBook Jaguar AJ6 Engine Management System Manual Jaguar XJ40 Electrical Guide 1988-89 Jaguar Classic Parts (Diagrams and Part Numbers) Cheers, Don |
There isn't a gas cap lever, if the car is centrally unlocked the flap should unlock too.
Larry |
Tough crowd - not suprised the OP hasn't been back.
Graham |
