1993 XJ6 cooling fan relay location?
Guest
Posts: n/a
Cooling fans quit working on my '93 XJ6. Checked the fuse, now I,m looking for a relay. Traced the wiring harnes up thru the left front fender well, but don't see a relay yet. Hanes manual says it should be up in that location somewhere.
Thanks,
Swingarm
Thanks,
Swingarm
It is, but no easy to see. From below, with the lower splash shield closing panel removed, and looking up. It's mounted on a braket in front of the emission cannister (round black cylincer).
Separate the connector in the harness, bteween the fans and the relay, and make sure it is not burned up. There is also two fuses for the fan circuit, I believe.
Gatsby
09-06-2015 11:52 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
