1993 jaguar xj6 (The knocking continues) Help!
Hello,
I am new to the forum but a frequent visitor. I have a 1993 jaguar xj6 in pretty much mint condition with only 88k I have recently done a lot of maintenance to it my self. From front to back as follows new cooling fan regulator, and module, new belts, new front shocks, bushings, and breaks. New rear struts, and bushings. New spring top plate, and new sub-frame bushings. I initially started with the rear struts thinking the loud knocking sound coming from the rear of the car on drivers side. (sounds like right above strut in trunk) would go away.
The noise continues even after all of the repairs. I have checked the a-frame bushings and they appear to be fine. There is a control arm im guessing that goes from rear end to the body aprox 12in long with bushings on each end that appear to be weak but i can not figure out what they are called to look up the part or bushings. Any info on this part or the problem that might be making the noise would be great. Thanks Scott
Received 10,757 Likes
Wishbone Assembly-Rear - Parts For XJ6 & XJ12 from (V)667829 to (V)708757 | Jaguar Classic Parts UK
stillfree79 (02-01-2014)
Item 13 in this illustration?
Scott
Just be advised that there are a couple of different part numbers depending on VIN. If the last 6 digits of you VIN are within the range mentioned in the above link, then you're OK. On earlier VINS there were a couple of choices. I don't know if the difference is subtle or signififcant.
stillfree79 (02-02-2014)
If you had a bad bushing and the strut wore through the top plate then that is definitely where the knocking would have been coming from.
Probably worth double checking that you reassembled the new spring/strut assembly correctly with the bushings and spacer sleeve in their correct positions and the top plate nut secured to the correct torque.
Roob0481 (02-28-2016)
BrentGardner
26
04-17-2024 05:19 PM
rusty37
06-07-2016 04:43 PM
FS[Central US]: 1999 XJ8 Parts or project car for sale Lawrence, KS
casepie
08-30-2015 09:49 PM
Jaguar Forums Editor
Jaguar Press release
08-27-2015 03:18 AM
