1993 Jaguar XJ6 Vanden Plas no air blowing from vents?
Hi guys, new Jaguar owner here, the car is not blowing any air from the vents, regardless of any settings, I can hear something moving in the dash when I change the speed settings on the air controls, but no sound of blowers or anything like that. Anyone have any idea what could be the problem? Thanks in advance!
If you have nothing from either blower, even on high, there's a fair chance you have problems with cold or cracked joints in the fuse boxes. It could of course be that both blowers are faulty/jammed etc, but you can perform a simple check to see if you have power to the blowers.
The brown wire from the fuse box to the blower is live at all times, even with ign off and should read 12v when probed at the blower connector. Check that first and tell us if you have power there or not. Also, take a look at this thread, but don't skip the test I mentioned above, eh? https://www.jaguarforums.com/forum/x...g-else-126775/ Larry |
