anti lock
i have an XJ6 - sovereign of 1992 3,2L and sometimes when i start the anti lock light remains but not always , i stop the engine and start again and mostly the light is out.i read some articles about that overvoltage relay dbc 4282 but i cannot find this relay , where is it located in the car? i looked in the trunk but no relays there besides for the antenna. Can someone indicate me the exact location??
relays location
The 1992 uses the TEVES system and NOT the earlier Bosch system with the overvolt relay.
bob |
Many thx Bob now i know at least something
I remember that there are 'blink-codes' for the TEVES system. There is a connector in the boot on the left? side under the trim carpet.
The codes are activated by 'shorting' across 2 pins in the connector. (NOT the RED wire!!!!!) I remember the rhyme 'short the red and it's DEAD'. Damage occurs when you short the red wire to another wire. The other wires are shorted and the indicator lamp should 'blink' a code. I have not done this in a decade so my memory isn't clear about all the details. bob |
