Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XJ40 ( XJ81 ) (https://www.jaguarforums.com/forum/xj40-xj81-25/)
-   -   Brakes giving way occasionally (https://www.jaguarforums.com/forum/xj40-xj81-25/brakes-giving-way-occasionally-290782/)
Ernest Knox Jul 9, 2025 08:55 AM
Two years ago I converted the hydraulic brake system in my "88 Vanden Plas to conventional brake booster. Occasionaly (about 1 in 20 times) when applying the brakes the pedal will give way and go almost to the floor. Brake fluid is at the proper level. Could it be an issue with the master cylinder, air in the system, or something else? Thanks in advance.
jerry_hoback Jul 10, 2025 05:54 AM
My first suspicion would be the master cylinder if it's been fine there 2 years, then air is unlikely.
Ernest Knox Jul 21, 2025 05:58 PM
The Master Cylinder is original and there was a good possibllity it was leaking and letting in air, so I sourced a new rebuild kit and replaced all of the internal parts with new ones from the kit. I had the brakes bled afterwards, and now they are as good as ever.
© 2026 MH Sub I, LLC dba Internet Brands
