High/low beam relay 1994 xj40
Hi all, I'm new to this forum so I hope there's someone who's got the answer to my problem. I have no high beam on the car. All else works fine but but no flasher or high beams. I've tested every conceivable circuit I can find and all seems ok. Except for the high/low beam relay. Where is it? The modules behind the lights are ok too. So, too summarise
Where is this relay located? Thanks a lot for any info regarding this problem. |
Originally Posted by Astroman
(Post 645984)
Where is this relay located? Thanks a lot for any info regarding this problem. Cheers, |
Hi ,thanks for your response. I've changed the modules and the problem persists. Could it be the lighting logic unit. I have literally tested everything apart from this.
Astro:
What about the high/low switch itself? Couldn't that also be the point of failure? Scott |
