XJ40 ( XJ81 ) 1986 - 1994
Horse Trainer/Grad student with 1989 Vanden Plas
Old Jun 29, 2010 | 11:28 PM
kabrumley's Avatar
Default Horse Trainer/Grad student with 1989 Vanden Plas
Hi Folks,
I went a little bonkers a couple of weeks ago and purchased a 1989 Vanden Plas online, bought a bus ticket to Chicago and drove it back to SD. The drivetrain is great but the car has its electrical issues. Most important at this time are the headlights, then the ac blower, then the heater . . . but one thing at a time.
The left side lowbeam doesn't work but everything is fine on highbeam. Highbeams, however, don't stay on--perhaps a steering column issue. I took the car to a Jag tech for a post purchase inspection today but after he used the phrase "thousands of dollars" my brain went the way of the driver's side lowbeam headlight. What do I need to do to at least get the headlights all working?
Thanks,
Keith Brumley
Old Jun 30, 2010 | 04:04 AM
Cadillac's Avatar
Welcome, I am moving your thread off to the XJ40 Forums so that you get faster responses
Old Jun 30, 2010 | 06:58 PM
kabrumley's Avatar
Default Headlight
Headlight issue has been resolved. It needed a . . . headlight.
Old Jul 2, 2010 | 10:29 AM
gunnerman's Avatar
Heh, yeah all that can be thousands unless you do it yourself. Go to autoparts store and pick up a haynes manual and a Cresent tool kit and dive right in.
Old Jul 3, 2010 | 10:40 AM
Hoskins1's Avatar
Keith,
I'm also a new owner of an 89 XJ6 Vanden Plas. I highly recomend reading the FAQ's in the XJ40 Forum (I bet you'll ask why you should be in the XJ40 Forum when you have an XJ6...someone else would have to explain it!).
Jag Bits is a great website, and there are a few more that I have yet to learn that others will certainly recomend.
Also, you may want to "google" and see if you can find any Jag Clubs in your state. Hey,.... I found here in Kentucky so anything's possible.
Lastley I would spend some time in the XJ40 forum just scrolling through and reading previous post's. I try to do it every day until I get to tired. You'll be amazed about what you can learn from reading in here,..... I often find solutions to problems I have with my Jag just by reading someone else's situation.
Good luck!
Old Jul 3, 2010 | 11:42 AM
+1^. This forum is all about 'many hands make light work'!
OK I'll go jump in the well, for a while now.
revauto
Sep 17, 2020 03:50 PM
JungleJonny
Oct 5, 2015 03:52 PM
Col. Sandurz
Sep 28, 2015 07:29 PM
42Ajd
Sep 26, 2015 07:04 PM
