Inside the Heater Blower
My son and I took apart a non-working heater blower motor to see about repairing it. If you have never opened one up, you may find this to be interesting.
1990 Jaguar Sovereign : Disassemble the Heater Blower | AndyRupert.com |
Originally Posted by andyrupert-com
(Post 851258)
If you're going to completely rebuild the blower you should also take a look at the speed control transistor circuitry, it's accessible by drilling out the three pop-rivets. If a fan only blows on high it's usually because the speed control circuit has a problem. One of the relays is used for high speed fan and by-passes the speed controller. I replaced the darlington transistor and all the other components on the speed control circuit board when I replaced the relays. Check out the threads on the blower repairs, there are quite a few detailed postings. |
