XJ40 ( XJ81 ) 1986 - 1994
Jaguar 93 XJ6 - burning smell.....?
Old Feb 17, 2014 | 01:38 AM
jaguar 93 xj6 man's Avatar
Post Jaguar 93 XJ6 - burning smell.....?
my jaguar 93 xj6 wont stay on without me acceleratin it for a while.A burn smell comin from motor by the heads. i check oil and oil looks fine no water in it.Have no idea what it is.If u guys have any ideas please let me know i would really appreciated it.also has problem taking off.
Old Feb 17, 2014 | 02:39 AM
Welcome to the forum jaguar 93 xj6 man,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
Old Feb 17, 2014 | 11:16 AM
MidwestJag's Avatar
Welcome.
Sounds to me like you may have a throttle problem and perhaps an oil leak. Regarding the smell, do you see any oil seepage at the valve cover gasket that might be making it's way to burn on the manifold? Sometimes the screws come loose, but even if the valve gasket needs to be replaced, it's not a huge job.
I also wonder if you have any fault codes on the VCM - Vehicle Control Monitor. Is the check engine light one? Once you turn off the car, turn the key to position II (without cranking, and press the VCM button. Note any faults on the display because that may begin to help point you in the right direction.
Cheers!
Scott
BrentGardner
29
Dec 16, 2024 12:13 AM
rusty37
Jun 7, 2016 04:43 PM
jm717
Feb 27, 2016 09:31 AM
Goncalo Proenca
Aug 29, 2015 03:53 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
