Oil cooler line leak at block
Hi,
Have an oil leak from the oil cooler line at block on a 1988 Jaguar XJ6. Car is in collector condition but from what I’m being told by mechanic fixing such a leak with a new o ring could be a terribly difficult job? He says we can try but on such an old car things can go sideways very quickly and then what? Does anyone have experience with these O-rings and if so are our concerns justified? Could we actually damage the cooler line itself by loosening, prying it to replace O-rings? Further to this do we actually need an OEM o -ring or will a similar size work? please and thanks |
Welcome to the forums milan,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to XJ40 (XJ6 1986-1994) forum. Members here with the same model will be able to help. Please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum. Graham |
Hello again
My car is a 1988 jaguar xj6 red collector condition that needs an oil leak fixed. Apparently the oil cooler line is leaking at block and could be a difficult fix. Is there any kind of work around to this? thanks Milan |
Oil cooler line 'O'ring seals are a common repair.
I suppose the line could be brittle and crack but the 'O'rings are still available. bob |
Not really hard job i did it twice without much problem, perhaps you could also do the filter housing gaskets while there, they also tend to leak, whole project is cheap and doesn't take much time
oil cooler line
Thanks Xjack
That is really good news, really good news. Now just have to find a mechanic to do this procedure. Cheers Gerry |
I had this not too long ago, I got the o-rings at my local hardware store. It really was an easy one... Good luck.
I replaced the cooler two weeks ago with the Jag bypass kit.
The cooler hoses are a potential point of failure which gives me heartburn. Installed a bypass kit and cut and chucked the rear of the two oil hoses and metal pipes. Removing the cooler itself and the front pipes is more involved and I left for another day. |
oil cooler lines
@Roger
thanks Roger, Heard of the bypass but didn't know a kit was available? Please where is this available? As a Canadian its frustrating that parts need to come from the USA. Cheers |
The X300 (AJ16) did not have the cooler but used a bypass devise.
The parts will bolt in to the AJ6 housing. bob |
The part numbers of the components in the kit are:
EBC4124 (1 per) EBC4244 (2 per) CAC5118 (4 per) |
Hi milan,
Just to give some visuals, your oil cooler lines connect to the underside of the oil filter housing and are sealed with the O-rings shown as part 9 in the diagram below. The hose half-brackets are secured by nut part 10 that threads onto a stud on the oil filter housing. https://cimg1.ibsrv.net/gimg/www.jag...40fb47787e.png You can see the part names and numbers here: https://www.jaguarclassicparts.com/u...-3-6-4-0-litre As Bob mentioned, on the X300s (and on the '93-'94 XJ40s), the oil cooler was eliminated and replaced by a "Bypass Pipe," part 4 in the diagram below. It is an aluminum casting that, along with the "Connector" pipes, part 6 (two required) and O-rings, part 7 (four required), simply recirculates the oil back into the crankcase, bypassing the cooler altogether. I believe the bypass pipe requires a longer mounting stud, part 3, since the original cooler hose half-brackets were significantly thinner. .https://cimg0.ibsrv.net/gimg/www.jag...c12546c8b4.png You can see the part names and numbers here: https://www.jaguarclassicparts.com/u...lter-4-0-litre Cheers, Don |
I didn't even bothered with the bypass on my old 40 and XJS and simply removed the oil cooler block entirely and bolted oil filter housing directly to the block using shorter bolts. Worked/works perfectly fine too.
Hello Don B
Thank you very much now to deal with spongy brakes. cheers Milan |
i know this is an old thread:
Having the same oil cooler line leak issue - anyone know the bolt size/length to remove the block and bolt the filter housing directly to the block? thanks |
Originally Posted by dtrain
(Post 2474590)
Having the same oil cooler line leak issue - anyone know the bolt size/length to remove the block and bolt the filter housing directly to the block? thanks Larry |
If anyone is curious the bolts are 8 x 1.25 and the replacements were 25mm long
