Parking Lights Intermittent
The parking lights and side marker lights go on and off intermittently. There is a relay module (yellow) that controls the following functions:
1 Auxillary power 2 Side Light positive 3 Aux Side lights 4 Cigarette lighter Is this relay module the likely culprit? I thought I reflowed the solder in this one when I had the intermittent no radio/no blower motor issue. Is this the same relay module for the radio and blower? If not, is it located under the glove box and behind the knee bolster panel? |
Hi supra-raleigh,
The locations of relay modules are given in the Electrical Guide, which you can download here: Jaguar XJ40 Electrical Guide 1993 Cheers, Don |
Is this relay module the prime suspect?
