XJ40 ( XJ81 ) 1986 - 1994
Remove lower wishbone
Old Mar 18, 2015 | 03:22 AM
mickvic's Avatar
anybody got any definiticve advice on position of this bush? like what happends if it is tilted forward a bit say at 1 o **** where is the pressure going?
Old Mar 18, 2015 | 11:15 AM
Don B's Avatar
Originally Posted by mickvic
well ive tried to get them in but it it wont work the distance from the mount at the back and the mount at the front is too long by at least a centimetre. Ill have to get the bushes out then back in again at 12 o clock i reckon.
If you have the rear pivot bolts installed and are trying to swing the subframe up to attach the Vee mounts, I had the same problem. I substituted 1/4" ratchet extensions for the bolts to give the subframe a little wiggle room so I could get the Vee mounts in position, then replaced the extensions with the bolts. You really do not want to change the orientation of the rear pivot bushes. The photos at the link below may help:
http://www.jag-lovers.org/snaps/snap...?id=1350312072
Cheers,
Don
Old Mar 18, 2015 | 10:23 PM
mickvic's Avatar
Don ive tried that getting wriggle room by putting in substitutes to the bolts. This enabled me to get the v mounts in position and partially bolted up. The problem them reverts back to the rear mounts which are "half a bolt hole" out. Did you have that problem and how did you resolve it? Mick
Old Mar 19, 2015 | 01:57 AM
mickvic's Avatar
Done it...phew...thanks for all the feedback and help. Got the v mounts in and done up, but not tight. probably only half a centimetre to move the eye of the bush to make it line up, so lifted the arm with a jack and dragged it down and forward with a crowbar hooked into the edge of the bush, and levering on the body of the car. Will try and post a pic. Lined up with little fuss, bolt in and hey presto. Other side harder but to my suprise same thing .
Now my only issue is the engine is a tad low, fan rubbing on radiator shroud. Any solutions for that? Mick
Old Mar 19, 2015 | 05:43 PM
Don B's Avatar
Hi mickvic,
Sorry I wasn't able to respond yesterday but I'm glad you got it done!
Is it possible that rather than the engine sitting low, the body is sitting high and needs to settle down, or that the Vee mounts are not actually fully seated?
Curious...
Don
Old Mar 20, 2015 | 05:47 AM
mickvic's Avatar
The v mounts look well and truly seated, the new rubber will make the body sit a fraction higher I suppose.... gearbox mount have any influence here?? It may well be quite old, the car has done 340,000km it could be origonal im sure the v mounts were. The pass side was badly split and the drivers side was soggy with oil. Hmm . See what shes like when I set her down on the wheels.
Old Mar 24, 2015 | 10:34 PM
mickvic's Avatar
Got one s
pring back in without the ******* taking my head off...phew. The spring pan bolts take a little lining up and you have to be careful not to cross thread them. Used the same bolts cleaned up and with lock tight against all instructions!!! I didnt paint the spring just cleaned it and sprayed it with fish oil
Old Mar 24, 2015 | 11:39 PM
  #28
mickvic's Avatar
By the way my springs have a daub of red paint all down one side on each coil, what does that mean?
Old Mar 25, 2015 | 01:18 PM
Don B's Avatar
mickvic,
The tip many of us have used to line up the spring pan is a pair of threaded rod sections about 8 inches long threaded into the inner spring pan bolt holes to guide the pan into position as the spring is compressed. See the last photo in the album at the link below:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
Old Mar 25, 2015 | 10:42 PM
  #30
mickvic's Avatar
thanks don yes i did use that method , and your illustrations have proven very useful, thankyou. Just cleaning up the hubs etc then get the rack back on the sway bar and the discs and hubs, plus the afm which I had to remove to get at the upper crossmember bolts.
Old Mar 26, 2015 | 09:12 AM
  #31
Don B's Avatar
The paint is a factory color code for the spring rate and possibly the ride height. The springs on sports models had a different color code from the regular "comfort" springs used on the other models, and of course the 12-cylinder cars got different springs. I can't recall the details, but somewhere in the Jag-Lovers archive there's an explanation of the color codes.
Cheers,
Don
Old Mar 27, 2015 | 03:45 AM
  #32
mickvic's Avatar
well one of the springs had red daubed down it and the other one had nothing, so who knows whats been going on with this car. The lh passenger side is a hard pedders shock and the drivers side looks like oem. Im not sure what side the springs came off... we shal see what happens!!
Wahooesprit
Dec 23, 2019 02:01 PM
pnwrs2000
Jan 15, 2018 07:20 PM
1964Daimler
Sep 9, 2015 11:28 AM
Saturbo
Sep 8, 2015 07:35 PM
Jay48
Sep 7, 2015 09:30 PM
