XJ40 ( XJ81 ) 1986 - 1994
Rplace starter on 1989XJ6automtic-best way?
Old Jan 15, 2011 | 06:02 PM
89JagDIYer's Avatar
Default Rplace starter on 1989XJ6automtic-best way?
Haynes manual says to drain tranny fluid (noooo!) then remove rear tranny support and lower rear of tranny (nooooo!) to get to bell housing bolts and upper starter mount bolt- yikes- is there an easier way? Im sure there would be if it was a manual tranny!
Old Jan 18, 2011 | 06:43 AM
rcarpenter's Avatar
Been there, done that ('88 XJ6 auto) and unfortunately the answer is noooo! This job is awful hard to do at home on jackstands. I would recommend other options, plus Haynes leaves out other removals you need to do.
Old Jan 19, 2011 | 08:57 PM
89JagDIYer's Avatar
yeah- after looking at it today I knew it was going to be tough- an amazing amount of work just to change a starter- they just assume you can spend a lot of money on repairs I guesse
KidRock'n
Oct 28, 2015 06:14 PM
backstop44
Sep 30, 2015 12:19 PM
Jahnese Alston
US Northeast
Sep 20, 2015 02:22 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
